.NET
jig problem?
9 REPLIES 9
Message 1 of 10
netcai
416 Views, 9 Replies
jig problem?
I wish to realize dynamic dimension like autocad do, but i am not familar with jig, could someone has some example about how to realize jig?
9 REPLIES 9
Message 2 of 10
in reply to: netcai
Have you looked at the EllipseJig sample from the SDK?
Albert
wrote in message news:4879122@discussion.autodesk.com...
Message 3 of 10
netcai
in reply to: netcai
Yes,I have looked at the ellipsejig sample, but I still don't understand how to use jig.My aids is to realize my continuous dimension command like autocad.
Message 4 of 10
in reply to: netcai
You should look at it one more time.
Its a very basic example of how to use Jig.
In Jig are few Essential functions that MUST be overriden:
entity() -> here you give back entity you operating on;
update() -> here you perform all update (set) operations on your entity;
sampler() -> here you perform any user input interaction;
The Sample Funktion doIt() must be written by you.
To start interacting with user use the drag() function.
It calls the sampler, update, entity functions and it calls the entitys
worlddraw() function to draw it on screen.
Those functions are absolue minimum to code an Jig mechanism for your
entity.
There are still fev functions you can use. For deteils read the docs.
Regards
Rex
schrieb im Newsbeitrag news:4880034@discussion.autodesk.com...
autocad.
Message 5 of 10
in reply to: netcai
Forgotten one function:
append() -> you need it to add your entity that is returned
by entity() function to DB. (If you want to add it to db 😉 ).
Regards
Rex
autocad.
Message 6 of 10
in reply to: netcai
I'm not sure what you mean by continuous dimension command. Which command
are you talking about?
Albert
wrote in message news:4880034@discussion.autodesk.com...
autocad.
Message 7 of 10
netcai
in reply to: netcai
continuous dimension command is my custom command,it works like autocad command ( _dimcontinue ),but doesn't need to select first dimension.
the following code works well, but in process of debug, I found the bug of rotationdimension again, rotationdimension's rotation property always throw a exception.
protected override bool Update()
try
switch (mPromptCounter)
case 0:
GetRotationAndDimensionDirectio();
break;
case 1:
break;
GetNewEndPoint();
RotatedDimension dimEnt = ((RotatedDimension)Entity);
//dimEnt = new RotatedDimension(mRotation, mStartPt, mNewEndPt, mLocPt, "", ObjectId.Null); // this line will make dynamic dimension dispear
dimEnt.XLine1Point = mStartPt;
dimEnt.XLine2Point = mNewEndPt;
dimEnt.DimLinePoint = mLocPt;
dimEnt.Rotation = mRotation; // this line will throw a exception
catch (System.Exception)
return false;
return true;
Message 8 of 10
in reply to: netcai
Can you post a little bit more code that I could try to run here? Are you
creating the dimEnt below with the default constructor? I have already
confirmed that to you that it won't work.
Albert
wrote in message news:4881324@discussion.autodesk.com...
a exception.
try
case 0:
break;
case 1:
break;
GetNewEndPoint();
dimension dispear
exception
return false;
return true;
Message 9 of 10
netcai
in reply to: netcai
albert, the attachment is my complete code.
Message 10 of 10
in reply to: netcai
Yes. You are using the default constructor of RotatedDimension. Chage
: base(new RotatedDimension())
to
: base(new RotatedDimension(mRotation, mStartPt, mNewEndPt, mLocPt, "",
ObjectId.Null))
Albert
wrote in message news:4881360@discussion.autodesk.com...
”Boost
