.NET
Valued Contributor
kcimos
Message 1 of 7 (268 Views)
iterating viewports
268 Views, 6 Replies
04-16-2012 04:07 PM
can someone provide a clear explaination (& maybe an example (or pseudocode)) of iterating all of the viewports (PS & MS) of all layout tabs in a (currently open) drawing & make them current & then lets  display a MSGBOX indicating something about that current VP.
Additionally, lets pretend that in an example DWG, the current VP is one of three MS VPs that exist in a layout tab called "TESTlayout" & we would like to reset that to the current layout & VP when our routine is finished.
_gile
Message 2 of 7 (252 Views)
Re : iterating viewports
04-16-2012 11:13 PM in reply to: kcimos
Here's a little example:
        [CommandMethod("Foo")]
        public void foo()
            Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                DBDictionary layouts = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                foreach (DBDictionaryEntry entry in layouts)
                    if (entry.Key != "Model")
                        Layout layout = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead);
                        string name = layout.LayoutName;
                        LayoutManager.Current.CurrentLayout = name;
                        foreach (ObjectId id in layout.GetViewports())
                            Viewport vp = (Viewport)tr.GetObject(id, OpenMode.ForRead);
                            int vpNum = vp.Number;
                            if (vpNum == 1)
                                ed.SwitchToPaperSpace();
                            else
                                ed.SwitchToModelSpace();
                                AcAp.SetSystemVariable("cvport", vpNum);
                            AcAp.ShowAlertDialog("Layout: " + name + "\nViewport number: " + vpNum.ToString());
                tr.Commit();
Gilles Chanteau
Valued Contributor
kcimos
Message 3 of 7 (223 Views)
Re: iterating viewports
04-17-2012 02:24 PM in reply to: kcimos
Thanks, that helps a bit.
I'm still not sure how to find the current viewport. I've seen stuff where people talk about finding the word "*ACTIVE" in the viewtable (?), but I'n not clear about this & how that relates to the current VP.
I'm using VB, but I'm semi-literate in C++
Valued Contributor
kcimos
Message 4 of 7 (220 Views)
04-17-2012 03:19 PM in reply to: kcimos
got it, very simple. I had found an example in the autodesk documentation which lead me astray, but I figured it out:
Dim strCurrentLayout AsString
Dim iCurrentTilemode AsInteger = Application.GetSystemVariable("TILEMODE")
Dim vpCurrentVP AsViewport
Using Tx AsTransaction = ACF.Db.TransactionManager.StartTransaction()
            strCurrentLayout =LayoutManager.Current.CurrentLayout
If iCurrentTilemode = 1 Then'      = Model Layout
Else                                'you're in a layout, so get current VP
                vpCurrentVP = (Tx.GetObject(ACF.acDoc.Editor.CurrentViewportObjectId,OpenMode.ForRead))
EndIf
Valued Contributor
kcimos
Message 5 of 7 (207 Views)
04-19-2012 03:26 PM in reply to: kcimos
OK, I've implemented proper procedures to iterate each layout & each viewport ( PS too) w/in each layout. I'm trying to use VPLAYER via sendcommand (or SendStringToExecute) to freeze a particular layer in the VP. It will not work. I get no errors, but it just soesn't work. Except it will freeze the layer in the VP that was origianlly current (which is also the last VP switched to) (even if it is not supposed to (becasue the user (me) didn't select that layout for inclusion in the list of layouts to have the layer frozen in that layout's VPs)).
It almost seems as if the SENDCOMMAND calls aren't being executed until the whole routine is finished, therefore only affecting the one VP.
I tried  a SendStringToExecute & that didn't work either.
I'd attach some code, but the routine is prretty complicated with multiple forms in different classes.
Valued Contributor
kcimos
Message 6 of 7 (206 Views)
04-19-2012 03:28 PM in reply to: kcimos
PS
in other sections of my code, the same exact VPLAYER string is used in a SENDCOMMAND & it works just fine. This section does NOT involve changing layouts or VPs.
_gile
Message 7 of 7 (193 Views)
04-19-2012 10:28 PM in reply to: kcimos
Hi
Try to avoid using Sendcommand or SendStringToExecute as they do not run synchronously.
The Viewport class has the method you need:
FreezeLayersInViewport()
ThawLayersInViewport()
ThawAllLayersInViewport()
Gilles Chanteau
You are not logged in.
Ask the Community
