issue with "has a command inprogress."
I am facing issue while saving file as
"xxxx" has a command inprogress.
Hit enter to cancel or [Retry]: *Cancel*
This issue comming, only when i am updating title block details in
Initialize() method,while opening drawing
Please help me on this.
Raman
Alfred.NESWADBA
you might have forgotten to .Dispose a DocumentLock in any of your functions/subs/....
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks for your reply on this.
Please let me know how i can .Dispose a DocumentLock
Raman
Alfred.NESWADBA
have you not locked the document by your code? If not, then forget this option;
...otherwise like every disposable object the syntax is:
myObject.Dispose
I'm not sure now (assuming you have not used a DocumentLock) if the same message might be thrown when you forgot a transaction to dispose? At least it's worth to look into it.
If the code is small enough (the part that gives us the chance to recreate your issue) then upload it here.
- alfred -
Alfred NESWADBA
