.NET
is it possible to determine the points of intersection of the Ray and Solid
4 REPLIES 4
andy_pu
974 Views, 4 Replies
Hi!
I need to find closest solid to point, so I trace a Ray from this point by Vector. Can I find points of intersection of Ray and Solid?
Thanks!!!
4 REPLIES 4
Balaji_Ram
in reply to: andy_pu
Hi Andy,
Please refer to this blog post :
http://adndevblog.typepad.com/autocad/2013/02/how-to-intersect-a-line-with-a-solid.html
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
bvyas89
Hi , to get intersection point between to entities you have to use 'entity.IntesectWith' function. With this function, you can get intersecting point. if for an entity if you get intersection point , you can add that entity in your list or array.
Please refer below link:
http://forums.autodesk.com/t5/NET/Find-intersection-point-of-two-lines/m-p/4769671#M38812
andy_pu
in reply to: bvyas89
Thanks! But IntersectWith not implemented for Solid
andy_pu
in reply to: Balaji_Ram
Thank you so much! This is exactly what I was looking!!! Many thanks!!!
”Boost
