.NET
andy_pu
Message 1 of 5 (229 Views)
is it possible to determine the points of intersection of the Ray and Solid
229 Views, 4 Replies
03-02-2014 11:58 PM
Hi!
I need to find closest solid to point, so I trace a Ray from this point by Vector. Can I find points of intersection of Ray and Solid?
Thanks!!!
ADN Support Specialist
Balaji_Ram
Message 2 of 5 (170 Views)
Re: is it possible to determine the points of intersection of the Ray and Solid
03-10-2014 05:28 AM in reply to: andy_pu
Hi Andy,
Please refer to this blog post :
http://adndevblog.typepad.com/autocad/2013/02/how-to-intersect-a-line-with-a-solid.html
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Active Contributor
bvyas89
Message 3 of 5 (150 Views)
03-10-2014 09:49 PM in reply to: andy_pu
Hi , to get intersection point between to entities you have to use 'entity.IntesectWith' function. With this function, you can get intersecting point. if for an entity if you get intersection point , you can add that entity in your list or array.
Please refer below link:
http://forums.autodesk.com/t5/NET/Find-intersection-point-of-two-lines/m-p/4769671#M38812
andy_pu
Message 4 of 5 (140 Views)
03-10-2014 11:02 PM in reply to: bvyas89
Thanks! But IntersectWith not implemented for Solid
andy_pu
Message 5 of 5 (119 Views)
03-11-2014 05:55 AM in reply to: Balaji_Ram
Thank you so much! This is exactly what I was looking!!! Many thanks!!!
You are not logged in.
Ask the Community
