.NET
how to use dxfcode.textfontfile , dxfcode.lineweight
2 REPLIES 2
hoyin0820
440 Views, 2 Replies
Public Class Zoom
<CommandMethod("ZO")> _
Public Sub ZO()
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument
Dim acDocEd As Editor = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument.Editor
Dim acCurDb As Database = acDoc.Database
Dim acTypValAr(4) As TypedValue
acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "<AND"), 0)
acTypValAr.SetValue(New TypedValue(DxfCode.Start, "TEXT,MTEXT"), 1)
acTypValAr.SetValue(New TypedValue(DxfCode.TextFontFile, "txt"), 2)
acTypValAr.SetValue(New TypedValue(DxfCode.lineweight, lineweight.lineweight030),3)
acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "AND>"), 4)
Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
Dim acSSPrompt As PromptSelectionResult
acSSPrompt = acDocEd.SelectAll(acSelFtr)
If acSSPrompt.Status <> PromptStatus.OK Then
Return
End If
Dim idCol As New ObjectIdCollection(acSSPrompt.Value.GetObjectIds())
ZoomObjects(idCol)
End Sub
this two lines do not work.
what problem is it ???
and does it exist text hiegh and text width on dxfcode???
2 REPLIES 2
hoyin0820
in reply to: hoyin0820
and i also have some question .
how can i get text and mtext properties on the drawing, such as text font, text height, text width
Dim acTypValAr(2) As TypedValue
acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "AND>"), 2)
If acSSPrompt.Status = PromptStatus.OK Then
' get text font, text hieght, text wdth
End If
mzakiralam
did you check the below link:
http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ff18cb41610ec0a2e719-7a6...
You can also check below links for MTEXT and TEXT group code:
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff18cb41610ec0a2e719-79d...
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff18cb41610ec0a2e719-79f...
You can also use system variable. if you want to use selection filter, I will recommend you to use different color for different object. Filter with color is also available
”Boost
