.NET
how to set or get the systemvariables
14 REPLIES 14
Message 1 of 15
1174 Views, 14 Replies
i want to get or set the system variables in managed .net application. please help me how to do this
Shaik Esu
14 REPLIES 14
Message 2 of 15
for setting:
Autodesk..autocad.Application.SetSystemVariable("PICKSTYLE", 0)
for read:
dim var as object
var=Autodesk..autocad.Application.GetSystemVariable("PICKSTYLE")
try this
Ciao
GPaolo
ha scritto nel messaggio
news:5477760@discussion.autodesk.com...
Shaik Esu
Message 3 of 15
It depends on the type of system variable.
For those that are saved with each drawing,
most are properties of the Database object.
For others, use the methods GPaulo shows.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5477760@discussion.autodesk.com...
Shaik Esu
Message 4 of 15
HugoCef
How i CAN set the DIM variable (DIMBLCK) in a vb.net application, I Need to change from "Closed Filled" To "_ArchiTick". please help me how to do this
Message 5 of 15
Hi
Here is two subs
First one will be to change arrow blocks
for the selected dimension, second one
will be to change system variables
You need to varnish these both because they
are was written quickly
~'J'~
_
Public Sub ChangeArrowBlock()
Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim prOpt As PromptEntityOptions = New PromptEntityOptions(vbCr & "Select Dimension To Change Arrow Block: ")
prOpt.SetRejectMessage(vbCr & "Only Dimensions may be selected.")
prOpt.AddAllowedClass(GetType(AlignedDimension), True)
prOpt.AddAllowedClass(GetType(RotatedDimension), True)
prOpt.AddAllowedClass(GetType(ArcDimension), True)
prOpt.AddAllowedClass(GetType(LineAngularDimension2), True)
prOpt.AddAllowedClass(GetType(DiametricDimension), True)
prOpt.AddAllowedClass(GetType(Point3AngularDimension), True)
prOpt.AddAllowedClass(GetType(RadialDimension), True)
prOpt.AddAllowedClass(GetType(RadialDimensionLarge), True)
Dim rs As PromptEntityResult = ed.GetEntity(prOpt)
If rs.Status = PromptStatus.OK Then
Using trans As Transaction = db.TransactionManager.StartTransaction()
Dim dime As Dimension = CType(trans.GetObject(rs.ObjectId, OpenMode.ForWrite), Dimension)
If Not dime Is Nothing Then
' here we go:
Dim bt As BlockTable = CType(trans.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
Dim btr As BlockTableRecord = CType(trans.GetObject(bt.Item("_ARCHTICK"), OpenMode.ForRead), BlockTableRecord)
Dim blkId As ObjectId = btr.ObjectId
Dim dtr As DimStyleTableRecord = dime.GetDimstyleData
dtr.Dimblk = blkId
dtr.Dimblk1 = blkId
dtr.Dimblk2 = blkId
MsgBox(dtr.Name)
dime.SetDimstyleData(dtr)
' if you need to change arrows for dimstyle also:
'db.SetDimstyleData(dtr)
ed.Regen()
Else
MsgBox("You are stumb as always, Fatty")
trans.Commit()
End Using
End Sub
_
Public Sub ChangeArrowBlockSysVar()
db.Dimblk = blkId
db.Dimblk1 = blkId
db.Dimblk2 = blkId
trans.Commit()
End Using
End Sub
Message 6 of 15
This wrong:
Instead of all of that, only this is needed:
prOpt.AddAllowedClass(GetType(Dimension), False)
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
wrote in message news:5622592@discussion.autodesk.com...
Hi
Here is two subs
~'J'~
_
' here we go:
dtr.Dimblk = blkId
dtr.Dimblk1 = blkId
dtr.Dimblk2 = blkId
MsgBox(dtr.Name)
ed.Regen()
Else
trans.Commit()
End Using
End Sub
_
db.Dimblk = blkId
db.Dimblk1 = blkId
db.Dimblk2 = blkId
trans.Commit()
End Using
End Sub
Message 7 of 15
Thanks, but I've tried it before, will not
worked for me (A2007)
and works good with exact types
~'J'~
Message 8 of 15
Sorry Fatty, you're mistaken.
It works perfectly here.
wrote in message news:5624432@discussion.autodesk.com...
~'J'~
Message 9 of 15
Pardon me, Tony
You are right as always, I was mistaken
because I 've selected the certain dimension types
only, therefore cause is on
my friends called me Oleg
Cheers 🙂
~'J'~
Message 10 of 15
Fatty, if you only want certain dimension types,
then what you show is fine, but I don't think it
was what the OP seemed to need.
wrote in message news:5624453@discussion.autodesk.com...
Pardon me, Tony
Cheers 🙂
~'J'~
Message 11 of 15
Agreed 🙂
~'J'~
Message 12 of 15
HugoCef
Thanks for answer me, but my problem is, when I'm creating my dimstyle ("DIM96") I have to set-Up the variables I don't have problems with most of them, but when i try to set up "DIMBLK" = "_ARCHTICK" the program show me a message like that "Value of type string cannot be converted to _Autodesk.autocad.databaseservices.objectId" I know is asking me for a block but i don't know how i can set up it
Thanks Again in advance
Message 13 of 15
Sorry for the late
Try this instead
~'J'~
_
Public Sub MakeDimStyle()
Dim idd As ObjectId = CreateDimSt("DIM96", "_ARCHTICK")
End Sub
Public Shared Function CreateDimSt(ByVal dimstName As String, ByVal blkArrow As String) As ObjectId
Dim dimstId As ObjectId
Application.SetSystemVariable("DIMBLK", blkArrow)
Using tr As Transaction = db.TransactionManager.StartTransaction
Try
Dim dt As DimStyleTable = CType(tr.GetObject(db.DimStyleTableId, OpenMode.ForWrite), DimStyleTable)
If dt.Has(dimstName) Then
dimstId = dt(dimstName)
If dimstId.IsErased Then
Dim dtr As DimStyleTableRecord = CType(tr.GetObject(dimstId, OpenMode.ForWrite, True), DimStyleTableRecord)
dtr.Erase(False)
Else
Dim bt As BlockTable = CType(tr.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
Dim blkId As ObjectId = bt(blkArrow)
Dim dtr As DimStyleTableRecord = New DimStyleTableRecord
dtr.Name = dimstName
dtr.Dimblk = blkId
dtr.Dimblk1 = blkId
dtr.Dimblk2 = blkId
'// add another variables here
dt.UpgradeOpen()
dimstId = dt.Add(dtr)
tr.AddNewlyCreatedDBObject(dtr, True)
db.Dimstyle = dimstId
tr.Commit()
Finally
CType(tr, IDisposable).Dispose()
End Try
End Using
Return dimstId
End Function
Message 14 of 15
alainpoupart5574
This piece of code will work fine only if the block "_ArchTick" exists in the blocktablerecord database. If none of the existing dimension style in the current drawing uses this block, it won't be existing.
Now the question is ... how can we programmatically create any dimstyle using specific block instead of arrow without having to access system variables such as DIMBLK, DIMBLK1, DIMBLK2 and DIMLDRBLK
Message 15 of 15
tahershaker
Dear Tony Tanzillo,
I've the same problem . it give me
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eKeyNotFound
at Autodesk.AutoCAD.DatabaseServices.SymbolTable.get_Item(String key)
at BarBendingDet.BarBendingDet.CreateAndAssignALayer() in E:\Visual Studio 2012\Projects\autcad.NET\0000BarBendingDet\BarBendingDet\BarBendingDet\BarBendingDet.vb:line 295
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 19.0.0.0
Win32 Version: 19.0.55.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcdbMgd.DLL
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 3.5.19.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AdApplicationFrame.DLL
AdWindows
Assembly Version: 3.5.21.0
Win32 Version: 3.5.21.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AdWindows.DLL
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/Acmgd.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcWindows.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/en-US/AcWindows.resources.DLL
PresentationUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcFusion
Assembly Version: 1.0.4413.25327
Win32 Version: 0.2.0.230
CodeBase: file:///c:/program%20files/autodesk/applicationplugins/fusionplugin2013.bundle/contents/win32/acfusion.arx
AcFusionRes
Assembly Version: 0.2.0.230
CodeBase: file:///C:/Program%20Files/Autodesk/ApplicationPlugins/FusionPlugin2013.bundle/Contents/Win32/AcFusionRes.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcWindows.dll
System.Windows.Forms
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
ManagedMC3
Assembly Version: 6.4.0.0
Win32 Version: 6.4.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/ManagedMC3.DLL
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
AcLivePreviewContext
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/en-US/AcLayer.resources.DLL
PresentationFramework.Luna
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcMrUI.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/en-US/AcMrUi.resources.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
BarBendingDet
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///E:/Visual%20Studio%202012/Projects/autcad.NET/0000BarBendingDet/BarBendingDet/BarBendingDet/bin/Debug/BarBendingDet.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 11.0.50938.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
”Boost
