.NET
Valued Contributor
swaywood
Message 1 of 15 (459 Views)
how to get the true name of an anonymous block?
459 Views, 14 Replies
12-27-2013 06:41 AM
now i can get the anonymous blockname like 'uxxx', but i want to know the original block name before the insert changed to an anonymous block.
ps,the block is not a dynamic block.
Valued Mentor
jeff
Message 2 of 15 (455 Views)
Re: how to get the true name of an anonymous block?
12-27-2013 06:54 AM in reply to: swaywood
You can use BlockReference.DynamicBlockTableRecord to open the BlockTableRecord and get its name property but if it is not dynamic not sure how that will help.
You can also find your answers @ TheSwamp
Valued Contributor
swaywood
Message 3 of 15 (443 Views)
12-27-2013 07:27 AM in reply to: jeff
thack you for your reply,i will try as a dynamic block, but maybe it dosnt work.
Valued Mentor
gasty1001
Message 4 of 15 (425 Views)
12-27-2013 09:27 AM in reply to: swaywood
This has been asked before, something like this should help:
Public Shared Function GetEffectiveName(ByVal blkref As BlockReference, ByVal acTrans As Transaction) As String
        Dim btr As BlockTableRecord
        btr = acTrans.GetObject(blkref.DynamicBlockTableRecord, OpenMode.ForRead)
        Return btr.Name
    End Function
 Gaston Nunez
Active Contributor
DouceDeux
Message 5 of 15 (419 Views)
12-27-2013 10:06 AM in reply to: gasty1001
Think you can help me with this Gaston?
It's related to this topic.
http://forums.autodesk.com/t5/NET/Dynamic-Block-Programatic-creation/td-p/4715109
Valued Mentor
gasty1001
Message 6 of 15 (409 Views)
12-27-2013 11:35 AM in reply to: DouceDeux
I think you should take a look to the developer documentation, this link will help you to understand the object hierarchy in AutoCAD: Hierarchy
May be I'm wrong, but I think you can't create create a dynamic block definition with .NET API. Another thing is a block reference, and there is no problem creating one and driving its parameters with the .NET API.
Gaston Nunez
Valued Contributor
swaywood
Message 7 of 15 (384 Views)
12-28-2013 01:19 AM in reply to: gasty1001
hi i have tried, but allway get the "*uxxx" name.
my block is not a dynamic block
_gile
Message 8 of 15 (380 Views)
12-28-2013 01:30 AM in reply to: swaywood
If you could attach a little dwg file with one or more of these anonymous blocks.
Gilles Chanteau
Valued Contributor
swaywood
Message 9 of 15 (373 Views)
12-28-2013 04:15 AM in reply to: swaywood
i attached the dwg file
the block name contains "ISO A1"
and the block description contains "ISO A1" too
i just want to get the blockreforence which contains 'ISO A1" , by block name or by block descrption.
_gile
Message 10 of 15 (367 Views)
12-28-2013 05:12 AM in reply to: swaywood
I don't know how it is possible to get this kind of non-dynamic anonymous block table record...
Anyway, you can get the block table record description using the BlockTableRecord.Comments property.
Gilles Chanteau
You are not logged in.
Ask the Community
