hi all:
how to get the model space object id by select in paper space without enter the viewport?
anyone done this before?
best regards
swaywood
Solved by norman.yuan. Go to Solution.
I'm not sure to understand the question, because there is only one modelspace in the drawing, independent from any "select in paperspace without ..."
Look to the samples in the doc's from Autodesk, there you see how to get access to modelspace quite often: >>>click<<<
' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
- alfred -
Hi,alfred:
Thanks for your reply.
my question is:
i want to get the objectid which the owner is model space by select in paperspace without enter the floating viewport.
normally we can not select anything in modelspace without enter the floating viewport, but i want to get the line whitch exactly through the mouse point i click in paper space.
i use the getentity method, i just want to get the line or lineid, i am not really want to let the line 'selected', so it is not necessary to enter the floating viewport.
best regards
swaywood
By "model space object id", if you mean id of objects that are in modelspace, I guess what you want is to select objects that can be seen from a paperspace viewport. If so, please see this:
http://drive-cad-with-code.blogspot.ca/2014/03/selecting-entities-in-modelspace.html
hi, yuan:
i can not open the link you tell me.
could you post it here?
many thanks.
Well, I have no problem to click the link and get to the article. But I place the link here again:
You can also click "Drive AutoCAD with Code" at the bottom of my reply.
hi,yuan:
i am sorry, i can not open the web site yet.
could you send the article by email?
my email address is : 54408802@qq.com
thanks a lot.
best wishes.
swaywood
HI,yuan:
I recieved your PDF, thank you very much, you are really a kind man.
but,could you kindly send me the code only? I can not copy the code, it changed to messy code when i try to paste it.
i know this is too much to ask, but, i really need this code, thank again.
my email is:54408802@qq.com
best wishes
swaywood
