.NET
how to find the blockrefercen in a rectangle area which bound by to point?
10 REPLIES 10
Message 1 of 11
swaywood
877 Views, 10 Replies
is there any method without looking throgh all the blockrenferences?
Tags (1)
10 REPLIES 10
Message 2 of 11
in reply to: swaywood
Can you clear Little bit more regarding your Problem? you can also your Screen shot.
Message 3 of 11
Hallex
Try this code
    <CommandMethod("CSW")> _
        Public Sub TestSelectWindow()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            '' dummy object types for test:
            Dim objects() As String = New String() {"INSERT", "LINE", "LWPOLYLINE", "CIRCLE"}
            '' dummy layers for test:
            Dim layers() As String = New String() {"DIM", "DWGRU", "ANNO-TLB", "Defpoints"}
            Dim layerfilt As String = String.Join(",", layers)
            Dim objfilt As String = String.Join(",", objects)
            '' Create a TypedValue array to define the filter by object types (dxf code 0) and layers (dxf code 8)
            Dim tvs() As TypedValue = New TypedValue() {New TypedValue(0, objfilt), New TypedValue(8, layerfilt)}
            '' Assign the filter criteria to a SelectionFilter object
            Dim filter As SelectionFilter = New SelectionFilter(tvs)
            Dim ppo As PromptPointOptions = New PromptPointOptions(vbLf & "Specify lower legt corner of window: ")
            Dim pres As PromptPointResult = ed.GetPoint(ppo)
            If pres.Status <> PromptStatus.OK Then Return
            Dim p1 As Point3d = pres.Value
            Dim pco As PromptCornerOptions = New PromptCornerOptions(vbLf & "Opposite corner point: ", p1)
            pres = ed.GetCorner(pco)
            Dim p2 As Point3d = pres.Value
            '' Request for objects to be selected in the drawing area
            Dim res As PromptSelectionResult
            res = ed.SelectCrossingWindow(p1, p2, filter)
            '' If the prompt status is OK, objects were selected
            'If res.Status = PromptStatus.OK Then
            Dim sset As SelectionSet = res.Value
            If sset.Count > 0 Then
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Number of objects selected: " & sset.Count.ToString)
            Else
                Return
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    For Each sobj As SelectedObject In sset
                        Dim ent As Entity = DirectCast(tr.GetObject(sobj.ObjectId, OpenMode.ForRead, False), Entity)
                        Dim blk As BlockReference = TryCast(ent, BlockReference)
                        If blk IsNot Nothing Then
                            ed.WriteMessage(vbLf & "Block Name: {0}", blk.Name)
                        Dim circ As Circle = TryCast(ent, Circle)
                        If circ IsNot Nothing Then
                            ed.WriteMessage(vbLf & "Radius: {0}", circ.Radius.ToString())
                        Dim pline As Polyline = TryCast(ent, Polyline)
                        If pline IsNot Nothing Then
                            ed.WriteMessage(vbLf & "Number Of Vertices: {0}", pline.NumberOfVertices.ToString())
                        Dim ln As Line = TryCast(ent, Line)
                        If ln IsNot Nothing Then
                            ed.WriteMessage(vbLf & "Start Point: {0}", ln.StartPoint.ToString())
                    Next
                    tr.Commit()
                Catch ex As System.Exception
                    ed.WriteMessage(ex.StackTrace & vbLf & ex.StackTrace)
                End Try
            End Using
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 4 of 11
swaywood
hi,mzakiralam,
i lost two letters, 'by to point' shall be 'by two points', sorry for that.
best regards
swaywood
Message 5 of 11
swaywood
in reply to: Hallex
hi, Hallex,
thank you for your reply, your method is correct, but i want to find another method which will use LINQ.
Message 6 of 11
Hallex
Better yet show us you code you're started with,
or upload the image to make a sense
Message 7 of 11
_gile
I'm not sure to understand what you mean with "using Linq".
If you meant using Linq to avoid using a selection set (e.g. using from a side database), her's an example:
Query syntax:
        private ObjectId[] FindBlockReferencesInRectangle(Point3d pt1, Point3d pt2, Database db)
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
            using (Line line = new Line(pt1, pt2))
                Extents3d bound = line.GeometricExtents;
                BlockTableRecord modelSpace = (BlockTableRecord)tr.GetObject(
                  SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                Func<ObjectId, bool> isBlockReference = (id =>
                    id.ObjectClass == RXClass.GetClass(typeof(BlockReference)));
                Func<ObjectId, bool> isInside = (id =>
                    BlockReference br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                    Extents3d exts = new Extents3d(bound.MinPoint, bound.MaxPoint);
                    exts.AddExtents(br.GeometricExtents);
                    return bound.IsEqualTo(exts);
                var blocks =
                    from ObjectId id in modelSpace
                    where isBlockReference(id) && isInside(id)
                    select id;
                return blocks.ToArray();
Extension methods syntax:
                return modelSpace
                    .Cast<ObjectId>()
                    .Where(isBlockReference)
                    .Where(isInside)
                    .ToArray();
Gilles Chanteau
GileCAD
GitHub
Message 8 of 11
swaywood
in reply to: _gile
hi,giles,
that's exactly what i expect, thank you so much.
regards
swaywood
Message 9 of 11
_gile
Hi swaywood,
I'm glad it helps.
I also like the functional style available with Linq for the .NET "historic" languages (VB and C#), it is the "natural" way of coding with F#:
let findBlocksInRectangle pt1 pt2 (db : Database) =
    use tr = db.TransactionManager.StartOpenCloseTransaction()
    use line = new Line(pt1, pt2)
    let bound = line.GeometricExtents
    let rxc = RXClass.GetClass(typeof<BlockReference>)
    let isBlock (id : ObjectId) =  id.ObjectClass = rxc
    let isInside (id : ObjectId) =
        let br = tr.GetObject(id, OpenMode.ForRead) :?> BlockReference
        let exts = new Extents3d(bound.MinPoint, bound.MaxPoint)
        exts.IsEqualTo(bound)
    (tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead)
    :?> BlockTableRecord)
    |> Seq.cast<ObjectId>
    |> Seq.filter isBlock
    |> Seq.filter isInside
    |> Seq.toArray
Anyway all these functions do scan the whole model space entities to get all the block references and filter those which are inside the rectangle.
They are all absolutely equivalent to the following one written in a classic imperative style:
            return QueryForBlocksInRectangle(pt1, pt2, db).ToArray();
        private IEnumerable<ObjectId> QueryForBlocksInRectangle(Point3d pt1, Point3d pt2, Database db)
                RXClass brClass = RXClass.GetClass(typeof(BlockReference));
                foreach (ObjectId id in modelSpace)
                    if (id.ObjectClass == brClass)
                        if (bound.IsEqualTo(exts))
                            yield return id;
Gilles Chanteau
GileCAD
GitHub
Message 10 of 11
swaywood
in reply to: _gile
Hi,Gilles:
I am not familiar with F#.
I think linq is more efficient to find the result. I will have a try.
Thanks again
swaywood
Message 11 of 11
_gile
I do not think Linq is more efficient.
It's more a different way of coding. Functional style is more declarative: you write what you want (nearly the same way you think) instead of writing how to do it.
Gilles Chanteau
GileCAD
GitHub
”Boost
