.NET
how to fillet line and arc?
24 REPLIES 24
Message 1 of 25
2708 Views, 24 Replies
is there a way to do that programatically? fillet a line and arc
24 REPLIES 24
Message 21 of 25
this simple test has concentric arcs and the lines happen to pass through the center
the arcs may not always be concentric, the lines not always radial
trying to generalize the problem so it would fit with any(within reason) conditions
the arcs may not always lay more or less horizontal, though i could add that as a condition for the user to always adjust them that way if need be....
i'm fine with replacing with new objects
but i still have to know where those objects go(startpoint,endpoint,angle, whatever)
i'm sorry to be so dense, but i'm not seeing how i have less to figure out by creating new objects versus editing existing ones.
i wish i was smarter
Message 22 of 25
If you're not subject to the concenric/radial constraint, the problem
becomes more difficult because the arcs could intersect, and have
coincident endpoints with the lines.
I don't know if I can help with a more-or-less complete reinvention
of the FILLET command, because that is simply not trivial given all
of the possible conditions.
Message 23 of 25
the arcs will never intersect each other
the arcs and lines will not start out with coincident points since they are the result of offsetting the original arcs and lines by some distance.
it is the new coincident points i'm needing to calculate.
I agree it's not seeming trivial in my mind, i just wanted to make sure that was true and not just me not seeing the simple obvious method. (i have a tendency to overcomplicate things)
if i could figure out how to use your commandline class that might make it easier
i've looked at it a bit and the example supplied by the other poster where he was picking the entities
in my case i already have them but i have to learn how to convert his code from api to com or learn how to incorporate api into my com project.
Message 24 of 25
not that anyone cares but fwiw...
this is probably full of holes, but it seems to work on my first test dwg
this is just to find which of the multiple intersections returned by .IntersectWith are the "actual" intersections(closest)
  Private Function GetClosestIntersectionToOrigArc(ByVal ListOfPoints As Object, ByVal oarc As AcadArc) As Double()
    Dim Testpoint As Point3d
    Dim NewPointList() As Double
    Dim NewStartPoint(0 To 2) As Double
    Dim arcstart As Point3d = New Point3d(oarc.StartPoint)
    Dim arcEnd As Point3d = New Point3d(oarc.EndPoint)
    NewPointList = CType(ListOfPoints, Double())
    'because IntersectWith can return multiple intersections we have to find which is closest to original arc
    'it's either closest to arcstart or arcend
    Dim i As Short
    Dim colPoints As New Collection
    Dim testIntersection As Point3d
    'if the array isn't multiple of 3 we're hosed
        For i = 0 To UBound(NewPointList) Step 3
            testIntersection = New Point3d(NewPointList(i), NewPointList(i + 1), NewPointList(i + 2))
            colPoints.Add(testIntersection)
        Next
    Dim dTestDist As Double
    Dim currentClosePoint As Point3d
    Dim dCurrentLeastDist As Double
    For i = 1 To colPoints.Count
            Testpoint = colPoints.Item(i)
            If arcstart.DistanceTo(Testpoint) < arcEnd.DistanceTo(Testpoint) Then
                dTestDist = arcstart.DistanceTo(Testpoint)
                If i = 1 Then
                    dCurrentLeastDist = dTestDist
                    currentClosePoint = Testpoint
                Else
                    If dTestDist < dCurrentLeastDist Then
            Else ' testpoint is closer to end
                dTestDist = arcEnd.DistanceTo(Testpoint)
                If i = 1 Then
                Else
    Next
        Return DirectCast(currentClosePoint.ToArray(), Double())
  End Function
Message 25 of 25
Thanks Tony and Hallex for your help and ideas.
I finally got it all working...at least for the cases i've tested it on, probably some weird boundary shapes that may not work, but so far so good.
”Boost
