.NET
Valued Contributor
mpropst
Message 1 of 25 (1,017 Views)
how to fillet line and arc?
1017 Views, 24 Replies
07-19-2010 09:25 PM
is there a way to do that programatically? fillet a line and arc
Valued Mentor
Message 2 of 25 (1,017 Views)
Re: how to fillet line and arc?
07-19-2010 09:42 PM in reply to: mpropst
Yes, but not directly. You have to find the intersection points and then
calculate the new endpoints, and either replace the existing entities with
new ones, or manipulate the existing ones using the methods of the
Curve class (e.g, Extend(), GetSplitCurves(), and so on).
AcadXTabs for AutoCAD
Supporting AutoCAD 2000-2011
*Expert Elite*
Hallex
Message 3 of 25 (1,007 Views)
07-20-2010 03:54 AM in reply to: mpropst
Try CommandLine class from there:
http://www.caddzone.com/CommandLine.cs
it's likes me more :smileyhappy:
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Valued Contributor
mpropst
Message 4 of 25 (996 Views)
07-20-2010 05:58 AM in reply to: Hallex
l'll try and figure how to use a c# class in a vbnet app.
the manual calcs are making me feel stupid
*Expert Elite*
Hallex
Message 5 of 25 (995 Views)
07-20-2010 06:03 AM in reply to: mpropst
Sorry, I don't knew that you use VB.NET
Try handle this class instead:
http://www.caddzone.com/CommandLine.vb
~'J'~
Valued Contributor
mpropst
Message 6 of 25 (995 Views)
07-20-2010 06:10 AM in reply to: caddzone
hmmm, i'm not seeing it
i imported .Geometry
Dim oCurve As Curve2d
'cast arc to curve
    oCurve = CType(oArc3, Curve2d)
I don't get an .Extend method on the oCurve object
what am i missing?
(other than a brain)
thanks
mark
Valued Contributor
mpropst
Message 7 of 25 (992 Views)
07-20-2010 06:17 AM in reply to: Hallex
oh, thanks
Valued Contributor
mpropst
Message 8 of 25 (990 Views)
07-20-2010 06:23 AM in reply to: Hallex
Do you have a sample of it's use?
i'll search this group too.
*Expert Elite*
Hallex
Message 9 of 25 (988 Views)
07-20-2010 06:26 AM in reply to: mpropst
I have already wrote similar one few moons ago
Still searching in my codes but with no luck yet :smileysad:
~'J'~
*Expert Elite*
Hallex
Message 10 of 25 (982 Views)
07-20-2010 06:55 AM in reply to: mpropst
Huray, have found it in my garbage
Unfortunatelly it's on C# only
I'm pretty sure you could rewrite the code on VB.NET
(change AllowedType to arc and line)
        /// <summary>
        ///                     * FILLET LINES *
        /// </summary>
        [CommandMethod("filletlines", CommandFlags.UsePickSet | CommandFlags.Redraw)]
        public static void FL()
            Database db = HostApplicationServices.WorkingDatabase;
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                try
                    // Prompt for the fillet radius
                    PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter the fillet radius: ");
                    pdo.AllowZero = false;
                    pdo.AllowNegative = false;
                    pdo.AllowNone = false;
                    PromptDoubleResult pdr = ed.GetDouble(pdo);
                    if (pdr.Status != PromptStatus.OK)
                        return;
                    double rad = pdr.Value;
                    // Prompt for the lines to fillet
                    PromptEntityOptions peo = new PromptEntityOptions("\nSelect first line:");
                    peo.SetRejectMessage("\nSelect lines only");
                    peo.AddAllowedClass(typeof(Line), true);
                    PromptEntityResult per = ed.GetEntity(peo);
                    if (per.Status != PromptStatus.OK)
                        return;
                    ObjectId fid = per.ObjectId;
                    peo.Message = "\nSelect second line:";
                        return;
                    ObjectId sid = per.ObjectId;
                    ObjectId[] ids = new ObjectId[2];
                    ids[0] = fid;
                    ids[1] = sid;
                    DBObject obj1 = tr.GetObject(fid, OpenMode.ForWrite);
                    DBObject obj2 = tr.GetObject(sid, OpenMode.ForWrite);
                    acadApp.SetSystemVariable("FILLETRAD", rad);
                    acadApp.SetSystemVariable("CMDECHO", 0);
                    ResultBuffer buf = new ResultBuffer();
                    buf.Add(new TypedValue(5005, "_FILLET"));
                    buf.Add(new TypedValue(5006, fid));
                    buf.Add(new TypedValue(5006, sid));
                    acedCmd(buf.UnmanagedObject);
                    buf.Dispose();
                    acadApp.SetSystemVariable("CMDECHO", 1);
                    tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
~'J'~
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
