.NET
how datagridview to show data in a dwg?
5 REPLIES 5
ugur35
691 Views, 5 Replies
5 REPLIES 5
augusto.goncalves
in reply to: ugur35
Your question is not very clear...
It seems that the DWG image you share was produced with a Excel (or similar) table, which are usually created with a OLE object. If that is the case, unfortunately we don't have much APIs for it...
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
ugur35
in reply to: augusto.goncalves
thank you;
yes my goal to read the data in DWG
example dwg file :Drawing1.dwg
augusto.goncalves
in reply to: ugur35
Indeed this is an OLE object and there is no API to manipulate (i.e. extract its data)
Augusto Goncalves
ugur35
searched but did not find any.
can you help me ?
arcticad
in reply to: ugur35
http://forums.autodesk.com/t5/NET/I-want-to-read-data-from-a-DWG-excel-file-using-C/m-p/3927350/high...
This might help
(defun botsbuildbots() (botsbuildbots))
”Boost
