.NET
here is a sample of the code.
0 REPLIES 0
Message 1 of 1
199 Views, 0 Replies
Also, my nested dynamic blocks do not update. Is there something I need to do to get the nested blocks to update and get the attributes to come in on insert?
thanks
Private Sub btnGetDrawing_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnGetDrawing.Click
Dim getFile As New OpenFileDialog
Dim strFileName As String
'getFile.InitialDirectory = "C:\program files\autocad 2007\"
getFile.InitialDirectory = "N:\Everyone\Design & Compliance\AutoCAD Library & Templates\"
getFile.AddExtension = True
getFile.Filter = "Drawing Files|*.dwg"
If getFile.ShowDialog = Windows.Forms.DialogResult.OK Then
strFileName = getFile.FileName
Else
Exit Sub
Dim ED As Autodesk.AutoCAD.EditorInput.Editor
ED = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim InsertPoint As PromptPointResult
InsertPoint = ED.GetPoint("Pick Insertion Point")
Dim strSelectedName As String = Me.cmbBlockName.SelectedItem
Dim obj1 As ObjectId = InsertDrawing(strFileName, InsertPoint.Value)
Using DB As Database = HostApplicationServices.WorkingDatabase
Using Trans As Transaction = DB.TransactionManager.StartTransaction()
Try
Dim bRef As BlockReference = Trans.GetObject(obj1, OpenMode.ForWrite)
If bRef.IsDynamicBlock Then
m_BlkRefArray.Add(obj1)
GetNestedBlock(obj1)
DynamicProperties(obj1)
Else
MsgBox("Selected Block does not have Dynamic Properties", MsgBoxStyle.OkOnly, "Dynamic Information")
bRef.Erase(True)
Catch ex As System.Exception
MsgBox(ex.Message)
Finally
Trans.Commit()
Trans.Dispose()
End Try
End Using
End Using
End Sub
Private Sub DynamicProperties(ByVal objID1 As ObjectId)
Dim intNumProps As Integer = 0
If objID1.IsNull Then
ED.WriteMessage("Dynamic Block error, no block selected")
Exit Sub
lblMainBlock.Text = "File Name = " & strBlkName
Dim BlkRef As BlockReference
Dim dynBlkRefProps As DynamicBlockReferencePropertyCollection
Dim dynBlkRefProp As DynamicBlockReferenceProperty
Dim intPanelHeight As Integer
Try
For intBlockCount As Integer = 0 To m_BlkRefArray.Count - 1
BlkRef = Trans.GetObject(m_BlkRefArray(intBlockCount), OpenMode.ForRead) 'doublecheck
If intBlockCount > 0 Then
Dim intPanelTop As Integer
If intBlockCount = 1 Then
intPanelTop = 35 + intPanelHeight
Else
intPanelTop = 5 + intPanelHeight + intPanelTop
Dim Panel As New Panel
Panel.SuspendLayout()
Panel.BorderStyle = BorderStyle.FixedSingle
Panel.Location = New System.Drawing.Point(5, intPanelTop)
Panel.AutoScroll = False
Panel.Tag = CObj(intBlockCount)
Panel.Name = "pnlDynamicNest" & CStr(intBlockCount)
DynamicLabels(Panel, BlkRef.Id, Panel.Tag, Trans)
Dim i As Integer = 0
dynBlkRefProps = blkRef.DynamicBlockReferencePropertyCollection
intNumProps = dynBlkRefProps.Count
Dim PropList(intNumProps) As DynamicControl.DynamicControl
Dim l_DynamicNameArray As New ArrayList
Dim intTop As Integer
For Each dynBlkRefProp In dynBlkRefProps
PropList(i) = New DynamicControl.DynamicControl
Dim intLength As Integer = 0
If i = 0 Then
intTop = 40
Else
intTop = PropList(i - 1).Top + PropList(i).Height
PropList(i).Location = New System.Drawing.Point(5, intTop)
PropList(i).DynamicName = dynBlkRefProp.PropertyName
l_DynamicNameArray.Add(dynBlkRefProp.PropertyName)
PropList(i).DynamicDescription = dynBlkRefProp.Description
Dim objObject As Object()
objObject = dynBlkRefProp.GetAllowedValues()
Dim intCount As Integer = objObject.Length
For iCount As Integer = 0 To intCount - 1
PropList(i).AddValue(objObject(iCount))
Next iCount
PropList(i).SetValue(dynBlkRefProp.Value)
If objObject.Length > 0 Then
PropList(i).drHeight = objObject.Length * 15
Else
PropList(i).drHeight = 5
PropList(i).drWidth = 350
Panel.Controls.Add(PropList(i))
i += 1
Next
intPanelHeight = 45 + (intNumProps * PropList(i - 1).Height + (BlkRef.AttributeCollection.Count * 20))
Panel.Size = New System.Drawing.Size(380, intPanelHeight)
Me.grpDynamic.Controls.Add(Panel)
Panel.ResumeLayout()
m_DynamicNameArray.Add(l_DynamicNameArray)
If BlkRef.AttributeCollection.Count > 0 Then
GetAttributeInfo(Panel, Trans, BlkRef, intTop)
Else
BlkRef = Trans.GetObject(objID1, OpenMode.ForRead)
dynBlkRefProps = BlkRef.DynamicBlockReferencePropertyCollection
grpMainBlock.SuspendLayout()
Me.grpMainBlock.BorderStyle = BorderStyle.FixedSingle
If i = 0 Then
DynamicLabels(grpMainBlock, BlkRef.Id, grpMainBlock.Tag, Trans)
If i = 0 Then
intTop = 40
Else
PropList(i).Top = intTop
Next iCount
Else
' End If
'Dim dblScreen As Double = Screen.PrimaryScreen.Bounds.Height
Me.grpMainBlock.Tag = CObj(intBlockCount)
Me.grpMainBlock.Controls.Add(PropList(i))
i += 1
Next
intPanelHeight = 45 + (intNumProps * PropList(i - 1).Height)
grpMainBlock.Size = New System.Drawing.Size(380, intPanelHeight)
grpMainBlock.ResumeLayout()
GetAttributeInfo(grpMainBlock, Trans, BlkRef, intTop)
Next intBlockCount
MsgBox(ex.Message)
Finally
If (Not Trans Is Nothing) Then
Trans.Dispose()
Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
End Try
End Using
End Using
End Sub
0 REPLIES 0
”Boost
