.NET
global variable in .net
2 REPLIES 2
wesbird
394 Views, 2 Replies
I use C# to create DLL running inside AutoCAD. I have login function with all the enviroment setup. now my problem, once I login, I can not access the information in login process, like the username, and the user relate information I got from database, like enabled and disalbed command list.
When I was working in VBA, I use global variables to solve this problem. How I do it in .net?
Thank you very much
Merry Christmas
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
NathTay
in reply to: wesbird
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/csref/html/vclrftypesaccessmodifiers.asp
Regards - Nathan
wesbird
thank you, I will look at it
”Boost
