.NET
getting angle info from line
1 REPLY 1
dahovey
248 Views, 1 Reply
I'm trying to get the angle of a line. in autocad 2006 in you look at the properties of a line, there is a value for the angle...basicly the absolute angle of the line from start point to end point.
how do i get this angle from the .net objects...
i'm also need to get the angle between to lines...
dahovey@gmail.com
1 REPLY 1
in reply to: dahovey
Simple sample:
[code]
[CommandMethod("GetLineAngle")]
public void GetLineAngle()
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
PromptEntityOptions prOpt = new PromptEntityOptions("\nSelect Line entity: ");
prOpt.SetRejectMessage("\nOnly Lines may be selected.");
prOpt.AddAllowedClass(typeof(Line),true);
PromptEntityResult rs = ed.GetEntity(prOpt);
if (rs.Status == PromptStatus.OK) {
using (Transaction trans = db.TransactionManager.StartTransaction()) {
Line line = trans.GetObject(rs.ObjectId, OpenMode.ForRead) as Line;
if (line != null) {
Vector3d v = line.EndPoint - line.StartPoint;
Plane plane = new Plane(new Point3d(0,0,0),new Vector3d(0,0,1));
double ang = v.AngleOnPlane(plane) / Math.PI * 180;
ed.WriteMessage("\nLine angle = {0}", ang);
[/code]
”Boost
