.NET
Active Contributor
btmcad
Message 1 of 2 (181 Views)
getselection problem
181 Views, 1 Replies
12-04-2012 07:48 AM
I'm having an issue with "getselection". I've used this before without problems, however, when I run the attached code, the program cancels when it gets to PromptSelectionResult. It shows my prompt at the command line, but a cancel afterwards, and the program is ended. Any suggestions would be greatly appreciated.
<CommandMethod("CreateImage")> _
        Public Sub Main()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument()
            Dim ed As Editor = doc.Editor
            Dim docWindow As Window = doc.Window
            Dim db As Database = doc.Database
            docWindow.WindowState = Window.State.Normal
            Dim size As System.Drawing.Size = docWindow.GetSize
            ed.WriteMessage(vbCrLf + "Document Size:" + vbCrLf + size.ToString() + vbCrLf)
            Dim newSize As System.Drawing.Size = New System.Drawing.Size(950, 573) 'was 608
            docWindow.SetSize(newSize)
            ZoomDwg()
            Dim selectionOpts As PromptSelectionOptions = New PromptSelectionOptions
            selectionOpts.MessageForAdding = "Select Geometry for image:"
            selectionOpts.AllowDuplicates = False
            Dim selection As PromptSelectionResult = ed.GetSelection(selectionOpts)
            ' if the selection was successful
            If selection.Status = PromptStatus.OK Then
Valued Mentor
DiningPhilosopher
Message 2 of 2 (140 Views)
Re: getselection problem
12-07-2012 03:10 PM in reply to: btmcad
You can't change the size of the document window without cancelling the active command.
Start the LINE command and pick a point.
Then, resize the document window (or the AutoCAD application window if the document window is maximized)
What happens?
You are not logged in.
Ask the Community
