.NET
foreach MText in C#
2 REPLIES 2
590 Views, 2 Replies
foreach MText in C#
How can I write foreach to list all MText object in 0 layer ?
Thanks in advance.
2 REPLIES 2
_gile
You can use the Editor.SelectAll() method with a SelectionFilter or, if you need to also search within the block, iterate through all the BlockTableRecordS in BlockTable and foreach BlockTableRecord iterate through all ObjectId, check if the object is a MText and if its Layer is "0".
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Sorry for my late reply, the issue has been resolved.
Thank you very much!
”Boost
