This works for me.
Imports AcDb = Autodesk.AutoCAD.DatabaseServices
Imports AcGe = Autodesk.AutoCAD.Geometry
Imports System.IO
Module Module1
Friend Function InsertDrawing(ByVal dwgName As String, ByVal insPt As
AcGe.Point3d, _
ByVal scale As AcGe.Scale3d, ByVal rot As Double) As AcDb.ObjectId
Dim blkName As String = Path.GetFileNameWithoutExtension(dwgName)
Dim id As AcDb.ObjectId = Nothing
Using db As AcDb.Database =
AcDb.HostApplicationServices.WorkingDatabase
Using tr As AcDb.Transaction =
db.TransactionManager.StartTransaction
Try
Dim bt As AcDb.BlockTable = tr.GetObject(db.BlockTableId,
AcDb.OpenMode.ForRead, True)
If Not bt.Has(blkName) Then
Using sourceDb As AcDb.Database = New AcDb.Database(False,
False)
sourceDb.ReadDwgFile(dwgName, FileShare.Read, True, "")
id = db.Insert(dwgName, sourceDb, False)
Dim blk As AcDb.BlockTableRecord = tr.GetObject(id,
AcDb.OpenMode.ForWrite, False, True)
blk.Name = blkName
End Using
Else
id = bt.Item(blkName)
Dim btr As AcDb.BlockTableRecord =
tr.GetObject(db.CurrentSpaceId, AcDb.OpenMode.ForWrite, True)
Dim bref As AcDb.BlockReference = New
AcDb.BlockReference(insPt, id)
bref.ScaleFactors = scale
bref.Rotation = rot
btr.AppendEntity(bref)
tr.AddNewlyCreatedDBObject(bref, True)
tr.Commit()
Catch ex As Exception
MsgBox(ex.Message)
End Try
End Using
End Using
End Function
End Module
tp
escreveu na mensagem
news:5397002@discussion.autodesk.com...
I get a fatal error when exiting autocad, however the block does insert
fine. Does anyone see anything wrong with my code?
Private Sub cmbBlockName_SelectedIndexChanged(ByVal sender As Object, ByVal
e As System.EventArgs) Handles cmbBlockName.SelectedIndexChanged
Dim Doc As Document = Application.DocumentManager.MdiActiveDocument
Dim fName As String = "c:\program files\autocad
2007\306sidewallsection.dwg"
Dim Trans As Transaction = Doc.TransactionManager.StartTransaction
Dim DB As Database = New Database(False, False)
DB.ReadDwgFile(fName, FileShare.Read, True, Nothing)
Dim ED As Autodesk.AutoCAD.EditorInput.Editor
ED =
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim InsertPoint As PromptPointResult
Try
Dim idBTR As ObjectId =
Doc.Database.Insert("306sidewallsection", DB, False)
Dim BT As BlockTable =
Trans.GetObject(Doc.Database.BlockTableId, OpenMode.ForRead)
Dim BTR As BlockTableRecord =
Trans.GetObject(BT(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Me.Hide()
InsertPoint = ED.GetPoint("Pick Insertion Point")
Me.Show()
Dim BRef As BlockReference = New
BlockReference(InsertPoint.Value, idBTR)
BTR.AppendEntity(BRef)
Doc.TransactionManager.AddNewlyCreatedDBObject(BRef, True)
Catch ex As System.Exception
Finally
Trans.Commit()
Trans.Dispose()
End Try
End Sub
thanks
pat
