.NET
New Member
bammari
Message 1 of 6 (972 Views)
extract attributes from multiple AutoCAD files (500+)
972 Views, 5 Replies
10-21-2008 02:27 AM
I have a requirement to extract attributes from multiple AutoCAD files (500+) and export it to a text file or multiple text files. The purpose of the extraction is to find the total count for each of these attributes for BOQ and procurement purposes. The extracted data (in text or CSV format) will be loaded into another application. The tool to do the bulk extraction should be a command line tool to be called from the application that will load the data. Any help in this regard is greatly appreciated
Valued Contributor
AdammReilly
Message 2 of 6 (972 Views)
Re: extract attributes from multiple AutoCAD files (500+)
10-21-2008 08:28 AM in reply to: bammari
Have you tried the dataextraction command?
Adam Reilly
Dell Precision C1700, Windows 7 Professional SP1
Intel Xeon E3-1220 3.10GHz, 64bit
Nvidia Quadro K600
New Member
bammari
Message 3 of 6 (972 Views)
10-22-2008 12:46 AM in reply to: bammari
I tried data extraction command but this command extract for single AutoCAD file. I need extract from multiple AutoCAD files at the same time. Edited by: bammari on Oct 22, 2008 7:46 AM
*Tony Tanzillo
Message 4 of 6 (972 Views)
10-22-2008 08:17 AM in reply to: bammari
Data Extraction can extract from multiple drawing files
wihtout
opening them in the AutoCAD Editor.
Look at it again.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Member
amir_myself
Message 5 of 6 (972 Views)
10-26-2008 01:25 AM in reply to: bammari
Dear All,
I have a requirement to extract the block attributes of AUTOCAD dwg files to multiple text files. I tested one tool called AutoDWG Attribute Extractor which uses wizard to extract the block attributes of multiple AUTOCAD files into one text, csv or xls file. But i want to extract the AUTOCAD dwg files throgh command line and every dwg file should create one text,csv or xls file after extracting the attributes. So, please guide me how can I use command line to accomplish the above.
Any suggestion will be highly appreciated.
Thanks to all.
New Member
Abdul-Q
Message 6 of 6 (331 Views)
02-11-2013 11:40 PM in reply to: bammari
For single file attribute extraction use eattext command on command line
You are not logged in.
Ask the Community
