.NET
Distinguished Contributor
Alexander Rivilis
Message 11 of 13 (69 Views)
Re: exception: application busy
08-18-2006 02:31 AM in reply to: clear_zero
In which case AutoCAD tell you "would you like to save the file"? May be you try to open another dwg-file before saving previous? Then you need to save previous dwg-file before open another one. Message was edited by: Alexander Rivilis
clear_zero
Message 12 of 13 (69 Views)
08-18-2006 02:40 AM in reply to: clear_zero
while I am running a AutoCAD application at the moment with Single drawing compatibility mode, open file1 and do something
I create an AutoCAD object from VB.net under the same drawing(Single drawing compatibility) open file1 and do something, then there will be messagebox popup.
My code is open lots dwg file and insert something and close as a thread running in the background.
Alexander Rivilis
Message 13 of 13 (69 Views)
08-18-2006 02:45 AM in reply to: clear_zero
If system variable DBMOD not equal 0 and you try to open another dwg-file AutoCAD will be asked you with popup. You *MUST* save it before.
You are not logged in.
Announcements
Need installation help?
Ask the Community
