.NET
easiest way to do WCMATCH in .net?
9 REPLIES 9
Message 1 of 10
JamesMaeding
997 Views, 9 Replies
I am aware of regex and several other string methods, but have not seen a built in way of checking against multiple patterns allowing for asterisks.
Curious what others have come up with.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
9 REPLIES 9
Message 2 of 10
Hallex
in reply to: JamesMaeding
Try asteriks preceded by "`" character, kinda "`*mybad"
if string.StartWith("`*mybad") etc
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 10
JamesMaeding
in reply to: Hallex
I see, escape the *, good tip.
I will try that also with the contains method, thanks
Message 4 of 10
Hallex
Yes, 'Contains' method will be handy in this case,
Cheers 🙂
Message 5 of 10
Exactly the same as (wcmatch ...) in AutoLisp and acutWcMatch/acutWcMatchEx in ObjectARX doing:
Autodesk.AutoCAD.Internal.Utils.WcMatch(string str, string pattern);
Autodesk.AutoCAD.Internal.Utils.WcMatchEx(string str, string pattern, bool ignoreCase);
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 6 of 10
great suggestion, I saw your same post on theswamp from a while back.
I am actually doing a non-acad project, so have to use regular .net, but still cool to have access to acad's routines.
Message 7 of 10
Yes, but that's not the 'easiest' way Smiley Very Happy
namespace System
   public static class WcMatchExtensionMethods
      public static bool Matches( this string str, string pattern, bool ignoreCase )
         return Autodesk.AutoCAD.Internal.Utils.WcMatchEx( str, pattern, ignoreCase );
      public static bool Matches( this string str, string pattern )
         return Autodesk.AutoCAD.Internal.Utils.WcMatchEx( str, pattern, true );
Message 8 of 10
jeff
Honestly I have never really used Autolisp or Regex either.
This is only from 5 minutes a messing around since I thought it might be good to see what Regex was about. I only knew it had something to do with matching character in strings, but taking a quick look at WCMATCH and this article Converting Wildcards to Regexes this might be a start, but there are guys with AutoLisp and Regex experience around here and other forums that would much know a much better approach.
A little console program playing around
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Text.RegularExpressions;
namespace ConsoleApplication8
    class Program
        static void Main(string[] args)
            string poo = "I have no idea and I have spent 5 minutes on this and have no idea if it will work";
            Console.WriteLine(poo.WCMATCH("*z"));/////////////////////->False
            Console.WriteLine(poo.WCMATCH("*al"));////////////////////->False
            Console.WriteLine(poo.WCMATCH("min???s"));////////////////->True
            Console.WriteLine(poo.WCMATCH("*z", "*al", "min???s"));///->True
            Console.WriteLine(poo.WCMATCH("*z", "*al", "*ha"));///->True
            Console.ReadLine();
    public static class StringExtensions
        public static bool WCMATCH(this string text, params string[] patterns)
            foreach (string pat in patterns)
                string reg = s_wildcardToRegex(pat);
                if (Regex.Match(text, reg).Success)
                    return true;
            return false;
///////////source http://www.codeproject.com/Articles/11556/Converting-Wildcards-to-Regexes
        private static string s_wildcardToRegex(string pattern)
            return Regex.Escape(pattern).Replace("\\*", ".*").Replace("\\?", ".");
 *********Edit**********
DiningPhilosopher slipped in while I was posting and prime of example of what I meant when I I said other guys would know much better than I would. Actually I never said that but typed it.
You can also find your answers @ TheSwamp
Message 9 of 10
JamesMaeding
in reply to: jeff
wow, thanks for all the responses.
Message 10 of 10
Oh, Tony! Of course your version is beautiful and laconic. For this you have new kudos from me! Smiley Happy
Expert Elite Member
”Boost
