eNoInputFiler Error executing Document.ReadDwg()
I am getting a eNoInputFiler error executing Document.ReadDwg() when I am not executing the method as an AutoCAD command (i.e. not called from a method marked with a CommandMethod annotation). If I execute the code called from a method called as an AutoCAD command, it works fine.
I have tracked down what appears to be the cause: The command executes in document context (and Document.ReadDwg works) and the other call comes from application context (Application.DocumentManager.IsApplicationContext = True) and the function fails.
Any suggestions?
- Scott
phliberato
You need to lock the document.
Document doc = Application.DocumentManager.MdiActiveDocument;
            using (doc.LockDocument())
                using (Database db = new Database(false, false))
                        db.ReadDwgFile(filePath, FileOpenMode.OpenForReadAndWriteNoShare, true, null);
