I'm trying write VB.NET code to batch open a set of files and produce DXF files. I am transitioning from VBA to VB.NET and still have a lot to learn, but I'm making some progress (slowly). I have created a small version of the code that creates the error using a single file - see below. Two sample files are attached below. The "Without Viewport" file works fine. The "With Viewport" file is the one that vauses the error and only under the conditions described below.
The strange thing is that the error only occurs when the code tries to save the DXF file while in a layout and in Paper Space and there is a viewport in the same layout. It does not occur if you delete the viewport, or if you run the code when in a different layout, or in model space, or in floating model space.
I'm getting the following error:
eInvalidInput
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eInvalidInput
at Autodesk.AutoCAD.DatabaseServices.Database.DxfOut(String fileName, Int32 precision, Boolean saveThumbnailImage)
at ClassLibrary1.Class1.Test() in C:\Documents and Settings\TestUser\my documents\visual studio 2010\Projects\Test\Test\Class1.vb:line 35
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
Here is my code:
Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.Runtime Imports System.Windows.Forms Public Class Class1 <Autodesk.AutoCAD.Runtime.CommandMethod("runTest", CommandFlags.Session)> _ Public Sub Test() Dim AddFiles As New OpenFileDialog Dim sFileName As String Dim NewFile As Document Dim tr As Autodesk.AutoCAD.DatabaseServices.Transaction AddFiles.ShowReadOnly = False AddFiles.Multiselect = False AddFiles.CheckFileExists = True AddFiles.Filter = "AutoCAD Files (*.dwg)|*.dwg|All Files (*.*)|*.*" AddFiles.FileName = "" AddFiles.InitialDirectory = "C:\" If AddFiles.ShowDialog() = DialogResult.Cancel Then Exit Sub End If sFileName = AddFiles.FileName NewFile = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open( _ sFileName, False) sFileName = Strings.Left(sFileName, Strings.Len(sFileName) - 4) tr = NewFile.Database.TransactionManager.StartTransaction() Using (tr) NewFile.Database.DxfOut(sFileName & ".dxf", 16, True) End Using NewFile.CloseAndDiscard() End Sub End Class
I'm using VS2010 running AutoCAD 2010 on Win XP 32-bit. This laptop has VS2010 installed. I have also tesed on a desktop running AutoCAD 2010 on Win XP 64-bit and got the same results. The desktop does not have VS installed.
I believe a work-around is to have the code switch to model space before trying to save the DXF file, but I would prefer finding the true solution and to learn how to avoid thee problem.
Any help is appreciated.
Constantine
Looks like it will succeed if you use a side database.
sFileName = AddFiles.FileName Using tmpDb As New Database(False, True) tmpDb.ReadDwgFile(sFileName, FileShare.ReadWrite, True, "") tmpDb.DxfOut(Path.ChangeExtension(sFileName, "dxf"), 16, DwgVersion.Current) End Using
Note that if you use this method, you don't need CommandFlags.Session.
The "dxfout" command built into AutoCAD also succeeds. So as an alternative to using a side database, you could keep CommandFlags.Session and use Document.SendStringToExecute().
Dan,
Thank you very much, that works! Can you figure out or explain why the original code caused the error?
Also, I will be using the code in a batch process where it opens one file after another. Doesn't that mean I should keep the CommandFlags.Session setting, so that the values of any varaibles are mantained across multiple files?
Constantine
I can't figure out why the original code would fail. I will point out [in case it helps a more experienced developer explain] that if you use your original code, without CommandFlags.Session, and just export the active document (i.e. DocumentManager.MdiActiveDocument.Database.DxfOut(), it succeeds.
Regarding CommandFlags.Session, I don't think you need it if you use the "side database" technique. My understanding is that you only need CommandFlags.Session if you'll be changing the active Document. Using side databases, AutoCAD won't even create a Document object for the files you open -- hence no Session required despite the fact that you're processing multiple files.
-drg
Dan,
Thank you. I'm doing more thorough testing today, but so far the batch process is working well. One of the benefits of using the "side database" is that it runs MUCH faster. Although I miss seeing the files open and close on the screen.
Constantine
hey, i'm have error in here:
Dim oHatch As New Hatch()
oHatch.SetDatabaseDefaults()
Dim normal As New Vector3d(0.0, 0.0, 1.0)
oHatch.SetHatchPattern(HatchPatternType.PreDefined, "SOLID")
oHatch.ColorIndex = 8
oHatch.AppendLoop(HatchLoopTypes.Default, ObjIds)
oHatch.EvaluateHatch(True)
ents.Add(oHatch)
cad show megbox: eInvalidInput. Please help me
