.NET
Valued Contributor
sszabo
Message 1 of 10 (399 Views)
eInvalidInput thrown when trying to remove layerfilters
399 Views, 9 Replies
10-10-2013 11:45 AM
I am trying to remove all unprotected layer filters from a DWG and getting the following result:
Command: CLEANLF
Deleting layerfilter[0]: 'Test1'...
Autodesk.AutoCAD.Runtime.Exception: eInvalidInput
   at Autodesk.AutoCAD.LayerManager.LayerFilterCollection.Remove(LayerFilter value)
   at wauCmds.WauCmd.cleanLF_Method()
Deleting layerfilter[1]: 'Test2'...
Deleting layerfilter[2]: 'Group Filter1'...
Layerfilter 'All Used Layers' is protected
Layerfilter 'Unreconciled New Layers' is protected
Layerfilter 'Viewport Overrides' is protected
Layerfilter 'Xref' is protected
Here is the code that produced this output.  Any ideas why the Remove throws this exception?
    <CommandMethod("cleanLF")> _
    Public Sub cleanLF_Method()
        Dim ed As Editor = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
        Using docLock As DocumentLock = acDocMgr.MdiActiveDocument.LockDocument
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                For i As Int32 = 0 To db.LayerFilters.Root.NestedFilters.Count - 1
                    Dim deleteMe As LayerFilter = db.LayerFilters.Root.NestedFilters(i)
                    If deleteMe.AllowDelete Then
                        Try
                            ed.WriteMessage(String.Format("Deleting layerfilter[{0}]: '{1}'...", i, deleteMe.Name) + vbCrLf)
                            db.LayerFilters.Root.NestedFilters.Remove(deleteMe)
                        Catch ex As Exception
                            ed.WriteMessage(ex.ToString + vbCrLf)
                        End Try
                    Else
                        ed.WriteMessage(String.Format("Layerfilter '{0}' is protected", deleteMe.Name) + vbCrLf)
                    End If
                Next
            End Using
        End Using
    End Sub
 ps I am running AutoCAD 2013 SP1.1 PV: G.114.0
ADN Support Specialist
Balaji_Ram
Message 2 of 10 (351 Views)
Re: eInvalidInput thrown when trying to remove layerfilters
10-14-2013 03:12 AM in reply to: sszabo
Note these lines of code in this blog post : http://through-the-interface.typepad.com/through_the_interface/2008/07/adding-and-remo.html
lfc.Remove(lf);
db.LayerFilters = lft;
It is a local copy of the "LayerFilterTree" that is modified by removing a layer filter and then set back to database.
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Contributor
sszabo
Message 3 of 10 (339 Views)
10-14-2013 05:37 AM in reply to: Balaji_Ram
I changed the code as such, same result:
                Dim lft As LayerFilterTree = db.LayerFilters
                        Try
                            ed.WriteMessage(String.Format("Deleting layerfilter[{0}]: '{1}'", i, deleteMe.Name) + vbCrLf)
                        End Try
                    Else
                    End If
                Next
            End Using
        End Using
    End Sub
 I also tried adding tr.Commit() after the for loop, no change, the filters are still there.  There is an autocad dialog box that kicks in automatically when I try to open a drawing with 20000 layer filters and it cleans it up correctly.  I just need the same functionality through the API to prevent drawings from reaching that point to begin with.
Balaji_Ram
Message 4 of 10 (332 Views)
10-14-2013 06:10 AM in reply to: sszabo
Hi Steve,
Here is a sample code to delete the first deletable layer filter from the Layer filters collection.
    <CommandMethod("Test")> _
    Public Sub TestMethod()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim lft As Autodesk.AutoCAD.LayerManager.LayerFilterTree = db.LayerFilters
        Dim lfc As Autodesk.AutoCAD.LayerManager.LayerFilterCollection = lft.Root.NestedFilters
            Dim lf As Autodesk.AutoCAD.LayerManager.LayerFilter = lfc(i)
            If lf.AllowDelete Then
                Try
                    ed.WriteMessage(String.Format("Deleting layerfilter[{0}]: '{1}'...", i, lf.Name) + vbCrLf)
                    lfc.Remove(lf)
                    Exit For
                End Try
            Else
                ed.WriteMessage(String.Format("Layerfilter '{0}' is protected", lf.Name) + vbCrLf)
            End If
        Next
    End Sub
Balaji
Valued Contributor
sszabo
Message 5 of 10 (324 Views)
10-14-2013 08:28 AM in reply to: Balaji_Ram
Ok, thanks Balaji: your code sortof works.
Removing the Exit For still leaves about half of the filters intact but if I nest the for loop in a while loop and do multiple passes it does remove all layerfilters.
What made the difference is the lfc variable.  The original code works by simply assigning and using this variable, the last assignment (db.LayerFilters = lft) was not necessary:
                Dim lfc As LayerFilterCollection = lft.Root.NestedFilters
                For i As Int32 = 0 To lfc.Count - 1
                    Dim deleteMe As LayerFilter = lfc(i)
                        Try
                            lfc.Remove(deleteMe)
                        End Try
                    Else
                    End If
                Next
            End Using
        End Using
 Thanks again for your help.
Valued Contributor
sszabo
Message 6 of 10 (315 Views)
10-14-2013 09:05 AM in reply to: Balaji_Ram
One last thing to qualify my previous statement: that last assignment (db.LayerFilters = lft) was necessary for the while loop I mentioned above to clean up left overs in multiple passes.  Just to clarify this here is the solution that seems to be able to remove all layerfilters:
        Dim done As Boolean = False
        While Not done
            Dim filtersLeft As Int32 = 0
                Dim lf As LayerFilter = lfc(i)
                    Try
                        lfc.Remove(lf)
                    End Try
                Else
                    ed.WriteMessage(String.Format("Layerfilter '{0}' is protected. AD={1}",
                                                  lf.Name, lf.AutoDelete) + vbCrLf)
                End If
            Next
                    filtersLeft += 1
                    ed.WriteMessage(String.Format("LEFT layerfilter[{0}]: '{1}'...", i, lf.Name) + vbCrLf)
                End If
            Next
            If filtersLeft = 0 Then
                ed.WriteMessage(String.Format("DONE! filtersleft={0}", filtersLeft) + vbCrLf)
                done = True
            End If
        End While
If there is a less messy more elegant solution that doesn not necessitate multiple passes please let me know.
Steve
Balaji_Ram
Message 7 of 10 (297 Views)
10-14-2013 10:30 PM in reply to: sszabo
Hi Steve,
Can you try this ?
    <CommandMethod("DeleteAllLayerFilters")> _
    Public Sub DeleteAllLayerFilters()
        Dim totalFilters As Integer = lfc.Count
        Dim i As Integer = 0
        While i < totalFilters
            Dim lf As Autodesk.AutoCAD.LayerManager.LayerFilter = lfc.Item(i)
            ed.WriteMessage([String].Format("{0} Checking {1}...", Environment.NewLine, lf.Name))
                lfc.Remove(lf)
                totalFilters = lfc.Count
                i -= 1
                ed.WriteMessage([String].Format("{0} Deleted {1}", Environment.NewLine, lf.Name))
            End If
            i += 1
        End While
    End Sub
Balaji
Valued Contributor
sszabo
Message 8 of 10 (286 Views)
10-15-2013 06:52 AM in reply to: Balaji_Ram
Balaji,
This is a very elegant fast algorithm, kudos!
Thanks a bunch,
Steve
Member
geenakv
Message 9 of 10 (219 Views)
Can u Help Me-AutoDesk Group
01-27-2014 02:17 AM in reply to: sszabo
Hi Friends..!!!!
I am trying to do 1 project using vb.net and AutoCAD. In the drawing we have multiple layers and should separately store the Layer blocks with the block names in an Excel Application. I stored the Layer names.But all the entities in the drawing will be stored in the Excel file. I need one by one.
Thanks & Regards
Geena..
mzakiralam
Message 10 of 10 (209 Views)
Re: Can u Help Me-AutoDesk Group
01-27-2014 02:57 AM in reply to: geenakv
Hi geenakv,
you should create a new message for your Problem. Please create a new thread in this case. Other People will try to help you. you may notice that this thread has already been marked solved so nobody will look into your message. And please try to make clear what do you want actually. I am Little bit confuse what do you really want.
You are not logged in.
Ask the Community
