.NET
Valued Contributor
spanqy
Message 1 of 3 (295 Views)
eInvalidInput - PlotType.Layout
295 Views, 2 Replies
10-26-2012 08:40 AM
I am using the following code, which has worked sucessfully to import page setups across multiple drawings:
Dim psv As PlotSettingsValidator = PlotSettingsValidator.Current
psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Layout)     '<-- eInvalidInput
I have run into an issue recently, whereby the .SetPlotType line above fails with the following error:
?ex.Message
"eInvalidInput"
?ex.InnerException.ToString
Referenced object has a value of 'Nothing'.
After investigating this by opening the problem drawings, I found that though the current tab was set to a layout (CTAB = "Layout1"), the one and only viewport in the layout was "active".  If you view my attachment, you can visually see the condition I am describing.
Thi smakes sense, sicne the viewport is acrive, the Layout cannot be accessed (i.e. Nothing).
Is there a setvar I can use to check for this condition or is there a way to de-activate the viewport and set the focus back to paper space?
TIA
Valued Mentor
fieldguy
Message 2 of 3 (270 Views)
Re: eInvalidInput - PlotType.Layout
10-26-2012 03:25 PM in reply to: spanqy
Valued Contributor
spanqy
Message 3 of 3 (269 Views)
10-26-2012 03:27 PM in reply to: spanqy
I posted this to the regular AutoCAD group and got an answer:My Other Post
The answer is to check the value of the CVPORT setvar.  If equal to 1, then no viewports are active.
Kudos to CoJonez!
You are not logged in.
Ask the Community
