• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Member
    eGeneralModelingFailure when operating on large Solid3d object sets
    309 Views, 10 Replies
    03-22-2012 02:16 PM
    I suspect the solution to my problem is pretty simple, but I'll probably get pretty heavy on the explanation of what I am doing, hopefully to alleviate any confusion.
    This code was originally a VBA macro, but due to its terrible x64 performance, I have been transitioning it to VB.NET.  I have tried to keep it as close to the VBA code as possible, until I can get it to produce the same results as the VBA source.
    In the meantime, the code seems to function correctly, however, when I select larger object sets (the maximum number is not consistent), I get an eGeneralModelingFailure from VB.NET and "The Boolean operation on solid/or surface bodies failed.  Modeling Operation Error: Access Violation" in the AutoCAD commandline.
    My code is shown, but I have pared it down to what I think are the essential concepts.  The error is occuring in the IdentifyObject Sub, when I set sRegion1 to a section using SectionPlane.  I am not interested in keeping the results of sRegion1 or the XPlode array once I've made them, hence I don't add them to the database or anything.  I am concerned that maybe I should be disposing them or clearing them somehow.  Any ideas or advice would be appreciated.  Thanks!
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.Geometry
    Imports Autodesk.AutoCAD.EditorInput
    Imports System.Windows.Forms
    Imports System.Security.Permissions
    Imports System.IO
    Public Class FLACSmcrWriter
        <CommandMethod("A2F")> _
        Public Sub AutoCAD2FLACS()
    	Dim ObjectArray() As ObjectId 'Solid3d
            'Got user selected 3dsolids via filter and put all ObjectIDs into ObjectArray
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                For I = 0 To UBound(ObjectArray)
                    objFlacs = New FLACSObject 'a custom object
                    ProcessObject(acTrans.GetObject(ObjectArray(I), OpenMode.ForWrite), objFlacs)
                Next I
            End Using
    		'Writing some stuff out to text files
        End Sub
        Private Sub ProcessObject(ByVal obj As Solid3d, ByRef objFlacs As FLACSObject)
    		'Minor custom object setup
            'Determine object shape, orientation, and properties
            Call IdentifyObject(obj, Direction, Length, Radius, Width, Height, minP)
    		'Some other stuff
        End Sub
        Private Sub IdentifyObject(ByRef obj As Solid3d, ByRef Direction As String, ByRef Length As Double, ByRef Radius As Double, ByRef Width As Double, ByRef Height As Double, ByRef minP As Point3d)
            Dim maxP As Point3d
            Dim pnt1 As Point3d
            Dim sRegion1 As Region
            Dim xPlode As DBObjectCollection = New DBObjectCollection
            Dim xCount As Long
            Dim eye As Long
            rCount = 0
            xObj = 0
            pnt1 = ChangePoint(minP, minP, minP)
            minP = obj.GeometricExtents.MinPoint
            maxP = obj.GeometricExtents.MaxPoint
            Dim SectionPlane As Plane = New Plane(pnt1, pnt2, maxP)
            sRegion1 = obj.GetSection(SectionPlane)
            If Not sRegion1 Is Nothing Then
                sRegion1.Explode(xPlode)
                xCount = xPlode.Count - 1
                For eye = 0 To xCount
                    If TypeOf xPlode.Item(eye) Is Ellipse Or TypeOf xPlode.Item(eye) Is Circle Then
                        xObj = 1
                    End If
                Next eye
            Else
    	    Exit Sub
            End If
            xPlode.Clear()
    		'Lots of other similar tests ...
        End Sub
    End Class
    Please use plain text.
    Valued Contributor
    Re: eGeneralModelingFailure when operating on large Solid3d object sets
    03-22-2012 02:54 PM in reply to: wein3967
    Is this a typo?
    chiefbraincloud
    03-22-2012 03:10 PM in reply to: wein3967
    I believe you should be disposing the Region and the objects in the xplode collection, but I don't think failing to do so would give you the error you are getting.
    Active Member
    03-22-2012 04:01 PM in reply to: SEANT61
    SEANT61,
    No, I don't believe that is a typo.  I don't have the IDE (intellisense) in front of me, but I am pretty sure you can define a plane with 3 points.  It certainly doesn't throw any errors anyway.
    Oh, yes, pnt2 is defined in my "complete" code.  I'm sure it was just swept up in several of the Dim statements I removed.
    chiefbraincloud
    03-22-2012 04:04 PM in reply to: wein3967
    I think he was pointing out that pnt2 is not defined in the code you posted, but I am assuming that is just because its definition got axed when you cut down your code for posting.  You can certainly define a plane with 3 points.
    Active Member
    03-22-2012 04:05 PM in reply to: chiefbraincloud
    chiefbraincloud,
    I have tried putting a .Dispose() for both the sRegion1 and the xPlote objects, but it didn't seem to resolve the error.  I was also kind of assuming that since that code is inside the "Using" statement, they would be properly disposed of by the code when the "End Using" was hit.  Of course, the execution isn't making it that far right now.
    chiefbraincloud
    03-22-2012 04:10 PM in reply to: wein3967
    Since you are not adding them to the database, those objects are not associated with the transaction, and will therefore not be disposed by the using statement on the transaction.
    Like I said, I had a feeling that was not what was causing your problem, but I do believe they need to be disposed separately.
    Active Member
    03-22-2012 04:14 PM in reply to: chiefbraincloud
    chiefbraincloud,
    I'll certainly add the Dispose() statments back in, since regardless of the error, that is the proper practice.  Thanks.
    Valued Contributor
    03-23-2012 02:12 AM in reply to: wein3967
    Check all input if the error occurs at:
    It appears that Autodesk.AutoCAD.Geometry.Plane will not throw an exception if the three points are collinear.  It just returns an invalid Plane (with a normal of 0.0,0.0,0.0).
    Solid3Ds use a different tolerance setting than conventional 2D geometry – a GetSection may falter if the points describe a triangle that is too thin a sliver.
    Active Member
    03-23-2012 06:55 AM in reply to: SEANT61
    SEANT61,
    Thanks for your suggestion. I went ahead and verified that I was using the appropriate 3 points to create the plane, and that the created plane's normal was correct.
    Additionally, I ran the code until the error occurred. I then identified the object in the model and re-ran the code against that single object. At that point the code completed successfully.
    It is things like that, which were making me think that perhaps I wasn't disposing or clearing reasources properly. Since the code never errors on the same object, and if I select only one object, the code completes succesfully.
