.NET
dockable palette
3 REPLIES 3
nlvvch
278 Views, 3 Replies
dockable palette
hi
which item ( user control or windows form )shall i take for create dockable form in auto cad 2008 and using vs 2005.
in my project i take windows form, its docking well but controls are not displayed.
can u give good suggestion.
venkatesh
3 REPLIES 3
cadMeUp
in reply to: nlvvch
Check out the sample in the ObjectARX SDK at:
..\samples\dotNet\SimpleToolPalette
It gives a good working example.
nlvvch
in reply to: nlvvch
hi this sample is for open the exist one. this is does not solved my problem.
so i created one usercontrol form and i link to palette it is working well, my was main problem is when i minimized or close the document
the dockable form all controls are not visible.
can u give one sample for create dockable form..
venkatesh
cadMeUp
in reply to: nlvvch
Maybe you can provide your code to see where the problem is. You are using AutoCAD's toolpalletes? Is the form visible or does then entire form disappear?
”Boost
