different Between Database definitions
Amremad
Amremad
what's the different between
 Dim oDb As Database = HostApplicationServices.WorkingDatabase
 and
Dim oDb As Database = Application.DocumentManager.MdiActiveDocument.Database
and
Dim oDb As Database = Application.DocumentManager.MdiActiveDocument.Editor.Document.Database
DiningPhilosopher
In AutoCAD they return the same value.
HostApplicationServices is a way to access certain functions in non-AutoCAD host applications (e.g,. RealDWG), where there is no Document object.
Autodesk.AutoCAD.ApplicationServices.Application is a class from assembly acmgd.dll which references acdbmgd.dll
Autodesk.AutoCAD.DatabaseServices.HostApplicationServices is a class from acdbmgd.dll
Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase is the active working database of the single-threaded RealDWG process, which is an engine of AutoCAD without UI.
In AutoCAD, Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase is a pointer of Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database. So every time you change the active drawing on AutoCAD, it will set MdiActiveDocument.Database to WorkingDatabase. There are many MdiActiveDocument.Databases in DocumentManager, but there is only one WorkingDatabase which is a worker of MdiActiveDocument.Database.
In short, all AutoCAD database tasks are based on RealDWG engine, MdiActiveDocument.Database is an upper layer of WorkingDatabase.
You also see the another answer at the link.
-Khoa
www.netscriptcad.com
In short, in AutoCAD:
Application.DocumentManager.MdiActiveDocument.Database calls HostApplicationServices.WorkingDatabase to execute the drawing database job.
MdiActiveDocument.Editor.Document = MdiActiveDocument so MdiActiveDocument.Editor.Document.Database = MdiActiveDocument.Database
In RealDWG, there is only HostApplicationServices.WorkingDatabase
