.NET
diference between TransactionManager and Transaction
5 REPLIES 5
netcai
353 Views, 5 Replies
I am confused by samples in autocad and AutoCAD [1].NET labs. In autocad samples: the code is :
TransactionManager tm = db.TransactionManager;
Transaction trans = tm.StartTransaction(); // begin the transaction
try
newBtr.AppendEntity(circle); //Append our entities...
newBtr.AppendEntity(attDef);
newBtr.AppendEntity(ellipse);
tm.AddNewlyCreatedDBObject(circle, true); //Again, let the transaction know about our newly added entities.
tm.AddNewlyCreatedDBObject(attDef, true);
tm.AddNewlyCreatedDBObject(ellipse, true);
trans.Commit(); //All done, no errors? Go ahead and commit!
but in AutoCAD [1].NET labs,the code is :
try
trans.AddNewlyCreatedDBObject(circle, true); //Again, let the transaction know about our newly added entities.
trans.AddNewlyCreatedDBObject(attDef, true);
trans.AddNewlyCreatedDBObject(ellipse, true);
5 REPLIES 5
in reply to: netcai
There's no difference. This (somewhat confusing) duality in the .NET API is
due to the same duality in the underlying C++ API (granted, not a very good
reason). Using the transaction related methods on the TransactionManager is
equivalent of calling the same methods on the "top" transaction.
Albert
wrote in message news:4879129@discussion.autodesk.com...
transaction
try
transaction
try
netcai
in reply to: netcai
thanks albert.
Since there is no difference between TransactionManager and Transaction. in the following two methods ,Could you point out which one is better.
//method 1
public static void MainApp ( )
Database db = HostApplicationServices.WorkingDatabase;
try
LayerTableRecord ltr = new LayerTableRecord();
ltr.Name = "S_Cols_Pat1";
ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 251);
AddLayer(ltr, trans);
trans.Commit();
finally { trans.Dispose(); }
public static ObjectId AddLayer( LayerTableRecord ltr , Transaction trans)
ObjectId retId = ObjectId.Null;
LayerTable lt = trans.GetObject(Db.LayerTableId, OpenMode.ForWrite, false) as LayerTable;
if (!lt.Has(ltr.Name))
retId = lt.Add(ltr);
trans.AddNewlyCreatedDBObject(ltr, true);
else
retId = lt[ltr.Name];
return retId;
//method 2
public static void MainApp()
try
AddLayer(ltr);
trans.Commit();
public static ObjectId AddLayer( LayerTableRecord ltr )
LayerTable lt = tm.GetObject(Db.LayerTableId, OpenMode.ForWrite, false) as LayerTable;
tm.AddNewlyCreatedDBObject(ltr, true);
else
return retId;
in reply to: netcai
Like I said, technically they are equivalent. I prefer method 1 because it
is clearer there what's happening.
Albert
wrote in message news:4880032@discussion.autodesk.com...
thanks albert.
//method 1
try
trans.Commit();
trans)
else
return retId;
//method 2
try
AddLayer(ltr);
trans.Commit();
else
return retId;
in reply to: netcai
Since Autodesk is telling us that we need to go through
transactions to open objects, the TransactionManager's
methods that operate on the top transaction become
more important, because there can be many cases where
objects need to be opened for read, to examine them and
then closed immediately. Encapsulating something like
that into a library function would otherwise require it to
start and end a transaction just to open one object.
With the transaction manager, a library function that opens
an object can use the top transaction (if there is one) to do
it without having to incurr the overhead of starting/ending a
transaction
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
thanks albert.
one is better.
//method 1
try
trans.Commit();
else
return retId;
//method 2
try
AddLayer(ltr);
trans.Commit();
else
return retId;
in reply to: netcai
Library functions could also have an existing transaction passed to them.
Dan
"Tony Tanzillo" wrote in message
news:4880097@discussion.autodesk.com...
transaction
thanks albert.
one is better.
//method 1
try
trans.Commit();
trans)
else
return retId;
//method 2
try
AddLayer(ltr);
trans.Commit();
else
return retId;
”Boost
