I get this error sometimes when I try to start my project in debug mode.
Error 2 Cannot unregister assembly "X:\myPrograms\Plot01\bin\Debug\Plot01.dll". Could not load file or assembly 'acmgd, Version=17.0.54.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. Plot01
I have searched high and low for help on this.
I have set the "Copy Local" setting for both acdbmgd.dll and acmgd.dll to False.
My program is the simplest "Hello world" created using the C# template in VS 2005.
It runs fine the first time I run it. The second time gives me that message.
If I set the "Copy Local" to true on both dlls and run it again the program starts but the command will not work in AutoCAD.
If I then set the "Copy Local" to false the program works again.
I'm finding this happening on two different development machines so far.
I need help.
