.NET
Active Member
Message 1 of 3 (200 Views)
creating a text style
200 Views, 2 Replies
03-19-2013 06:10 AM
Hello Group, this is my attempt, taken from snippets given here, but i obviously havent got the whole picture:
PublicSharedSub CreateTextStyle(ByVal TextStyleName AsString, ByVal FontFileName AsString, ByVal OblAng AsDouble)
Dim DataB AsDatabase = Application.DocumentManager.MdiActiveDocument.Database
Dim MyTransaction AsTransaction = DataB.TransactionManager.StartTransaction()
Try
Dim MyBlockTable AsBlockTable = MyTransaction.GetObject(DataB.BlockTableId, OpenMode.ForRead)
Dim MyBlockTableRecord AsBlockTableRecord = MyTransaction.GetObject(MyBlockTable(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Dim MyTextStyleTable AsTextStyleTable = MyTransaction.GetObject(DataB.TextStyleTableId, OpenMode.ForRead)
'check to see if text style exists, and if not create text style
If MyTextStyleTable.Has(TextStyleName) = FalseThen
                    MyTextStyleTable.UpgradeOpen()
Dim MyTextStyleTableRecord AsNewTextStyleTableRecord
                    MyTextStyleTableRecord.FileName = FontFileName
                    MyTextStyleTableRecord.Name = TextStyleName
                    MyTextStyleTableRecord.ObliquingAngle = OblAng
                    MyTextStyleTable.Add(MyTextStyleTableRecord)
                    MyTransaction.AddNewlyCreatedDBObject(MyTextStyleTableRecord,
True)
EndIf
Finally
                MyTransaction.Commit()
                MyTransaction.Dispose()
EndTry
EndSub
and i call it from sub:
Call CreateTextStyle("330", "romans.shx", DTR(330))
but error comes up
at Autodesk.AutoCAD.DatabaseServices.Transaction.GetObject(ObjectId id, OpenMode mode, Boolean openErased, Boolean forceOpenOnLockedLayer)
any help would be appreciated !
Moderator
Alexander.Rivilis
Message 2 of 3 (189 Views)
Re: creating a text style
03-19-2013 06:58 AM in reply to: AcadApe
1. First of all let using Insert Code button:
2. What kind of error happened (full description and error code)?  Maybe eLockViolation ?  If so you have to Lock/Unlock document.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Member
Message 3 of 3 (177 Views)
03-19-2013 07:26 AM in reply to: AcadApe
Hi Alex,
nearly there then!
Dim
lock AsDocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument
etc....
lock.Dispose()
works fine, thank you for response
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
