.NET
Distinguished Contributor spu
spu
Message 1 of 3 (1,064 Views)
create paper space viewport and show some model portion in view
1064 Views, 2 Replies
11-11-2012 12:52 AM
We like to allow user to select a rectagular area in modal scpace. Then the code creates a paperscace viewport in a spcified layout. The viewport will show the selected area. Please find the old VBA code that achived this and the .net code I am trying with. .Net code always gives some exception.
VBA Code
 'Lets find the center of the viewport in paperspace.
    Dim center(0 To 2) As Double
    center(0) = newWidth / 2
    center(1) = newLength / 2
    center(2) = 0
    Dim lay As AcadLayout
    For Each ent In ThisDrawing.layouts
        If ent.Name = "Betsy" Then
            Set lay = ent
        End If
    Next
    ThisDrawing.ActiveLayout = lay
    ThisDrawing.ActiveSpace = acPaperSpace
    'Lets create the actual viewport
    Set newVport = ThisDrawing.PaperSpace.AddPViewport(center, newWidth, newLength)
    newVport.TrueColor = myclr
    ' Enable the viewport
    newVport.Display True
    ZoomExtents
    ' Turn on model space editing
    ThisDrawing.MSpace = True    'Here pls check
    ' Set newVport current
    ' (not always necessary but a good idea)
    ThisDrawing.ActivePViewport = newVport
    Dim ModalLeftLower(0 To 2) As Double
    Dim ModalRightUpper(0 To 2) As Double
    ModalLeftLower(0) = ModalLeftUpper(0)
    ModalLeftLower(1) = ModalRightBottom(1)
    ModalLeftLower(2) = 0
    ModalRightUpper(0) = ModalRightBottom(0)
    ModalRightUpper(1) = ModalLeftUpper(1)
    ModalRightUpper(2) = 0
    ' Zoom window in model space
    ZoomWindow ModalLeftLower, ModalRightUpper
    ' Turn model space editing off
    ThisDrawing.MSpace = False
More code
.Net Code
 Autodesk.AutoCAD.ApplicationServices.Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
      Autodesk.AutoCAD.DatabaseServices.Database db = doc.Database;
      Autodesk.AutoCAD.EditorInput.Editor ed = doc.Editor;
      // We're accessing drawing objects, so we need a transaction
      using (Autodesk.AutoCAD.DatabaseServices.Transaction tr = db.TransactionManager.StartTransaction())
        // Get the primary paperspace from the block table
        Autodesk.AutoCAD.DatabaseServices.BlockTable bt =  (Autodesk.AutoCAD.DatabaseServices.BlockTable)tr.GetObject(db.BlockTableId,Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead);
        Autodesk.AutoCAD.DatabaseServices.BlockTableRecord ps =(Autodesk.AutoCAD.DatabaseServices.BlockTableRecord)tr.GetObject(bt[Autodesk.AutoCAD.DatabaseServices.BlockTableRecord.PaperSpace], Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite);
         // Create a variety of objects for our clip boundaries
           //Autodesk.AutoCAD.DatabaseServices.DBObjectCollection objs = new Autodesk.AutoCAD.DatabaseServices.DBObjectCollection();
           // Create our viewport, adding that also
           SwitchTo("Betsy");
           Autodesk.AutoCAD.DatabaseServices.Viewport vp = new Autodesk.AutoCAD.DatabaseServices.Viewport();
           vp.SetDatabaseDefaults();
           vp.CenterPoint = new Autodesk.AutoCAD.Geometry.Point3d(newWidth/2, newLength/2, 0);
           vp.Width = newWidth;
           vp.Height = newLength;
            ps.AppendEntity(vp);
            tr.AddNewlyCreatedDBObject(vp, true);
            doc.Editor.SwitchToPaperSpace();
           //vp.ViewDirection = new Autodesk.AutoCAD.Geometry.Vector3d(1, 1, 1);
          //  vp.On = true;
            // Set the new viewport current via an imported ObjectARX function
          //  acedSetCurrentVPort(vp.UnmanagedObject);
            doc.Editor.SwitchToModelSpace();
          //  tr.Commit();
           Autodesk.AutoCAD.Geometry.Point3d ptll = new Autodesk.AutoCAD.Geometry.Point3d(ModalLeftUpper.X, ModalRightBottom.Y, 0);
              Autodesk.AutoCAD.Geometry.Point3d ptur = new Autodesk.AutoCAD.Geometry.Point3d(ModalRightBottom.X, ModalLeftUpper.Y, 0);
             Zoom.ZoomWindow(ptll, ptur);
            //Autodesk.AutoCAD.Geometry.Point3d ptll = new Autodesk.AutoCAD.Geometry.Point3d(0, 0, 0);
            //Autodesk.AutoCAD.Geometry.Point3d ptur = new Autodesk.AutoCAD.Geometry.Point3d(100, 100, 0);
            //Autodesk.AutoCAD.Interop.AcadApplication pApp;
            //pApp = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
            //pApp.ZoomWindow(ptll.ToArray(), ptur.ToArray());
             tr.Commit();
Shijith
ADN Support Specialist
Balaji_Ram
Message 2 of 3 (1,002 Views)
Re: create paper space viewport and show some model portion in view
11-20-2012 03:51 AM in reply to: spu
Hi Shijith,
I dont have a ready code to do exactly the same steps.
But here is a Devblog post that can give you a start.
http://adndevblog.typepad.com/autocad/2012/08/changing-zoom-in-paperspace-viewport.html
It sets the paperspace viewport parameters based on the database extents. You can modify it to set the viewport parameters based on any other rectangle corner points. In the sample code from the blog post, the "x_Min" and "x_Max" are the database extent points but in your case it will represent the extents of the selected rectangle in model space.
This will allow you to set the paperspace viewport to show the model within the selected rectangle.
Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
spu
Message 3 of 3 (944 Views)
12-04-2012 04:54 AM in reply to: Balaji_Ram
Thanks Balaji. It worked like a charm....
Shijith
You are not logged in.
Ask the Community
