.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
create paper space viewport and show some model portion in view
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We like to allow user to select a rectagular area in modal scpace. Then the code creates a paperscace viewport in a spcified layout. The viewport will show the selected area. Please find the old VBA code that achived this and the .net code I am trying with. .Net code always gives some exception.
VBA Code
'Lets find the center of the viewport in paperspace.
Dim center(0 To 2) As Double
center(0) = newWidth / 2
center(1) = newLength / 2
center(2) = 0
Dim lay As AcadLayout
For Each ent In ThisDrawing.layouts
If ent.Name = "Betsy" Then
Set lay = ent
End If
Next
ThisDrawing.ActiveLayout = lay
ThisDrawing.ActiveSpace = acPaperSpace
'Lets create the actual viewport
Set newVport = ThisDrawing.PaperSpace.AddPViewport(center, newWidth, newLength)
newVport.TrueColor = myclr
' Enable the viewport
newVport.Display True
ZoomExtents
' Turn on model space editing
ThisDrawing.MSpace = True 'Here pls check
' Set newVport current
' (not always necessary but a good idea)
ThisDrawing.ActivePViewport = newVport
Dim ModalLeftLower(0 To 2) As Double
Dim ModalRightUpper(0 To 2) As Double
ModalLeftLower(0) = ModalLeftUpper(0)
ModalLeftLower(1) = ModalRightBottom(1)
ModalLeftLower(2) = 0
ModalRightUpper(0) = ModalRightBottom(0)
ModalRightUpper(1) = ModalLeftUpper(1)
ModalRightUpper(2) = 0
' Zoom window in model space
ZoomWindow ModalLeftLower, ModalRightUpper
' Turn model space editing off
ThisDrawing.MSpace = False
More code
.Net Code
Autodesk.AutoCAD.ApplicationServices.Document doc = Autodesk.AutoCAD.ApplicationServices.Application.D
Autodesk.AutoCAD.DatabaseServices.Database db = doc.Database;
Autodesk.AutoCAD.EditorInput.Editor ed = doc.Editor;
// We're accessing drawing objects, so we need a transaction
using (Autodesk.AutoCAD.DatabaseServices.Transaction tr = db.TransactionManager.StartTransaction())
// Get the primary paperspace from the block table
Autodesk.AutoCAD.DatabaseServices.BlockTable bt = (Autodesk.AutoCAD.DatabaseServices.BlockTable)tr.G
Autodesk.AutoCAD.DatabaseServices.BlockTableRecord ps =(Autodesk.AutoCAD.DatabaseServices.BlockTableReco
// Create a variety of objects for our clip boundaries
//Autodesk.AutoCAD.DatabaseServices.DBObjectCollec
// Create our viewport, adding that also
SwitchTo("Betsy");
Autodesk.AutoCAD.DatabaseServices.Viewport vp = new Autodesk.AutoCAD.DatabaseServices.Viewport();
vp.SetDatabaseDefaults();
vp.CenterPoint = new Autodesk.AutoCAD.Geometry.Point3d(newWidth/2, newLength/2, 0);
vp.Width = newWidth;
vp.Height = newLength;
ps.AppendEntity(vp);
tr.AddNewlyCreatedDBObject(vp, true);
doc.Editor.SwitchToPaperSpace();
//vp.ViewDirection = new Autodesk.AutoCAD.Geometry.Vector3d(1, 1, 1);
// vp.On = true;
// Set the new viewport current via an imported ObjectARX function
// acedSetCurrentVPort(vp.UnmanagedObject);
doc.Editor.SwitchToModelSpace();
// tr.Commit();
Autodesk.AutoCAD.Geometry.Point3d ptll = new Autodesk.AutoCAD.Geometry.Point3d(ModalLeftUpper.X
Autodesk.AutoCAD.Geometry.Point3d ptur = new Autodesk.AutoCAD.Geometry.Point3d(ModalRightBottom
Zoom.ZoomWindow(ptll, ptur);
//Autodesk.AutoCAD.Geometry.Point3d ptll = new Autodesk.AutoCAD.Geometry.Point3d(0, 0, 0);
//Autodesk.AutoCAD.Geometry.Point3d ptur = new Autodesk.AutoCAD.Geometry.Point3d(100, 100, 0);
//Autodesk.AutoCAD.Interop.AcadApplication pApp;
//pApp = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk
//pApp.ZoomWindow(ptll.ToArray(), ptur.ToArray());
tr.Commit();
Shijith
Re: create paper space viewport and show some model portion in view
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Shijith,
I dont have a ready code to do exactly the same steps.
But here is a Devblog post that can give you a start.
http://adndevblog.typepad.com/autocad/2012/08/chan
It sets the paperspace viewport parameters based on the database extents. You can modify it to set the viewport parameters based on any other rectangle corner points. In the sample code from the blog post, the "x_Min" and "x_Max" are the database extent points but in your case it will represent the extents of the selected rectangle in model space.
This will allow you to set the paperspace viewport to show the model within the selected rectangle.
Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Balaji. It worked like a charm....
Shijith
