.NET
create line from dbpoints
2 REPLIES 2
gulzar25
446 Views, 2 Replies
How to create line from dbpoints?
2 REPLIES 2
hgasty1001
in reply to: gulzar25
Hi, try this sub, it will create a line with default values (layer, line type, etc)
Private Sub AddLine(ByVal dbp1 As DBPoint, ByVal dbp2 As DBPoint)
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = HostApplicationServices.WorkingDatabase()
        Using acTrans As Transaction = db.TransactionManager.StartTransaction()
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead)
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            Dim nl As New Line(dbp1.Position, dbp2.Position)
            acBlkTblRec.AppendEntity(nl)
            acTrans.AddNewlyCreatedDBObject(nl, True)
            acTrans.Commit()
        End Using
    End Sub
Gaston Nunez
gulzar25
in reply to: hgasty1001
HI,
Thanks a lot for the reply it worked.
Thankyou so much 🙂
Gulzar
”Boost
