.NET
convert property definition from vba to vb.net
0 REPLIES 0
Message 1 of 1
wang890
404 Views, 0 Replies
Public Property Let Filter(ByVal vData As String)
' Filters that the user can select in drowpdown combo
' Usage: Friendlyname1|*.ex1|Freindlyname2|*.ex2 etc.
' Default: "All Files (*.*)|*.*"
Dim pipepos As String
Do While InStr(vData, "|") > 0
  pipepos = InStr(vData, "|")
  If pipepos > 0 Then
    vData = Left$(vData, pipepos - 1) & vbNullChar & Right$(vData, Len(vData) - pipepos)
Loop
If Right$(vData, 2) <> vbNullChar & vbNullChar Then vData = vData & vbNullChar
mvarFilter = vData
End Property
Public Property Get Filter() As String
Dim nullpos As String
Dim tempfilter As String
tempfilter = mvarFilter
Do While InStr(tempfilter, vbNullChar) > 0
  nullpos = InStr(tempfilter, vbNullChar)
  If nullpos > 0 Then
    tempfilter = Left$(tempfilter, nullpos - 1) & vbNullChar & Right$(tempfilter, Len(tempfilter) - nullpos)
Loop
If Right$(tempfilter, 1) = "|" Then tempfilter = Left$(tempfilter, Len(tempfilter) - 1)
Filter = tempfilter
End Property
  can someone help me convert this from vba to vb.net?
i figured out the simple ones like from:
Public Property Let FileTitle(ByVal vData As String)
' The name of the file without path
mvarFileTitle = vData
End Property
Public Property Get FileTitle() As String
FileTitle = mvarFileTitle
End Property
to this:
    Public Property FileTitle As String
        Get
            Return mvarFileTitle
        End Get
        Set(ByVal value As String)
            mvarFileTitle = value
        End Set
    End Property
 thanks.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
0 REPLIES 0
”Boost
