.NET
convert Application.Path from VBA to .net
4 REPLIES 4
wesbird
265 Views, 4 Replies
I am convert one of my project from VBA to .net (C#). now I have problem to convert
Application.Path
to C#. I look everywhere but I can not find it. Should I have to look in Reflection ?
I really appreciate your help
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
4 REPLIES 4
jbooth
in reply to: wesbird
What you are probably looking for is in the System.Windows.Forms namespace:
System.Windows.Forms.Application.StartupPath
string sdllPath =
System.Reflection.Assembly.GetExecutingAssembly().Location;
wrote in message news:5092626@discussion.autodesk.com...
to convert
Application.Path
Reflection ?
Wes
Using System.Diagnostics;
Using System.IO;
string filename = Process.GetCurrentProcess().MainModule.FileName;
string path = Path.GetDirectoryName(filename);
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
Application.Path
Wes
wesbird
Thank Jason, Mark and Tony.
I tried all your code. Jason's and Tony's get exact what I want, like C:\Program Files\AutoCAD 2006
Mark's return the path of current dll file.
thank you all again.
Wes
”Boost
