.NET
Active Member
inner_es
Message 1 of 3 (317 Views)
changes in DocumentCollectionEventArgs in 2013
317 Views, 2 Replies
10-04-2012 11:35 PM
this code used to work in AutoCAD 2007-2012, but not in 2013
    xAcad = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
    ThisDrawing = xAcad.ActiveDocument
    Public Sub AddDocumentToBeDestroyedEvent()
        Try
            AddHandler Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.DocumentToBeDestroyed, AddressOf subDocumentToBeDestroyed
        Catch
        End Try
    End Sub
    Public Sub subDocumentToBeDestroyed(ByVal senderObj As Object, ByVal docColDocActEvtArgs As DocumentCollectionEventArgs)
        Try
            If ThisDrawing Is docColDocActEvtArgs.Document.AcadDocument Then
            Else
            End If
        Catch ex As System.Exception
            MsgBox("Error en docColDocAct: " & ex.Message)
        End Try
    End Sub
it sends the error 'AcadDocument' is not a member of 'Autodesk.AutoCAD.ApplicationServices.Document'
anybody knows the new way to check in both documents are equal?
Alfred.NESWADBA
Message 2 of 3 (310 Views)
Hi,Re: changes in DocumentCollectionEventArgs in 2013
10-05-2012 12:22 AM in reply to: inner_es
Use this code for 2013 the get the COM-object of the AutoCAD-document (im my snippet: AcadDoc)
Imports Autodesk.AutoCAD
CType(ApplicationServices.DocumentExtension.GetAcadDocument(AcadDoc), Interop.AcadDocument)
- alfred -
Alfred NESWADBA
Active Member
inner_es
Message 3 of 3 (298 Views)
Re: Hi,Re: changes in DocumentCollectionEventArgs in 2013
10-05-2012 08:30 AM in reply to: Alfred.NESWADBA
yep, this work
            If ThisDrawing Is CType(Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(docColDocActEvtArgs.Document), Autodesk.AutoCAD.Interop.AcadDocument) Then
thanks a lot
regards
You are not logged in.
Ask the Community
