.NET
wang890
Message 1 of 3 (481 Views)
change font in mtext
481 Views, 2 Replies
01-24-2012 11:21 AM
i have 26000 mtext that has overridden font inside the property. set to bold and print out look like crap.
see attached i want all the text to look like the text on the left. right is what they look like now. i just copied a few as an example.
can't find the font property in the mtext object:
PrivateSub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) HandlesButton1.Click
Dim doc AsDocument = Application.DocumentManager.MdiActiveDocument
Dim db AsDatabase = doc.Database
'Dim id As ObjectIdDim ed AsEditor = doc.Editor
Dim oBlock As BlockReference = NothingDim tv() As TypedValue = {NewTypedValue(DxfCode.Start, TextBox1.Text)}
', New TypedValue(DxfCode.LayerName, "Layer1")}Dim selFilter AsNewSelectionFilter(tv)
Dim ss AsSelectionSet = ed.SelectAll(selFilter).Value
Using trans AsTransaction = db.TransactionManager.StartTransaction()
TryDim bt AsBlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
ForEach selObj As SelectedObject Inss
'trans.GetObject(selObj.ObjectId, OpenMode.ForWrite).Erase()Dim oText As MText = CType(trans.GetObject(selObj.ObjectId, OpenMode.ForWrite), MText)
Next
trans.Commit()
Catch'ex As Exception' MsgBox("Error: " + ex.Message)EndTryEndUsingEndSub
Civil 3D 2012
Work: Xeon W3503, 12GB, Quadro 2000, Yamakasi Sparta 301 + Dell PH2211
Home: 3930k, 12GB, GTX 590, U3011, QX2710
*Expert Elite*
chiefbraincloud
Message 2 of 3 (468 Views)
Re: change font in mtext
01-24-2012 12:50 PM in reply to: wang890
The font is specified (or overridden) in the Content of the Mtext.  In your example drawing you will see that the beginning of the Content is "\Fbold.shx;"
tyronebk
Message 3 of 3 (466 Views)
01-24-2012 12:58 PM in reply to: wang890
If you want to remove the formatting overrides from MText you should just be able to set the:
MText.Contents = MText.Text
The Contents string holds all the text and formatting. Text just hold the text contents.
If the above removes too much of the formatting you may have to parse the Contents string and remove any of the unwanted formatting strings (in this case it is probably just the "\Fbold.shx;" at the start of the Contents string).
Edit: Removed extra slash.
You are not logged in.
Announcements
Need installation help?
Ask the Community
