.NET
change font in mtext
2 REPLIES 2
wang890
893 Views, 2 Replies
i have 26000 mtext that has overridden font inside the property. set to bold and print out look like crap.
see attached i want all the text to look like the text on the left. right is what they look like now. i just copied a few as an example.
can't find the font property in the mtext object:
PrivateSub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) HandlesButton1.Click
Dim doc AsDocument = Application.DocumentManager.MdiActiveDocument
Dim db AsDatabase = doc.Database
'Dim id As ObjectIdDim ed AsEditor = doc.Editor
Dim oBlock As BlockReference = NothingDim tv() As TypedValue = {NewTypedValue(DxfCode.Start, TextBox1.Text)}
', New TypedValue(DxfCode.LayerName, "Layer1")}Dim selFilter AsNewSelectionFilter(tv)
Dim ss AsSelectionSet = ed.SelectAll(selFilter).Value
Using trans AsTransaction = db.TransactionManager.StartTransaction()
TryDim bt AsBlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
ForEach selObj As SelectedObject Inss
'trans.GetObject(selObj.ObjectId, OpenMode.ForWrite).Erase()Dim oText As MText = CType(trans.GetObject(selObj.ObjectId, OpenMode.ForWrite), MText)
Next
trans.Commit()
Catch'ex As Exception' MsgBox("Error: " + ex.Message)EndTryEndUsingEndSub
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
2 REPLIES 2
chiefbraincloud
in reply to: wang890
The font is specified (or overridden) in the Content of the Mtext.  In your example drawing you will see that the beginning of the Content is "\Fbold.shx;"
tyronebk
If you want to remove the formatting overrides from MText you should just be able to set the:
MText.Contents = MText.Text
The Contents string holds all the text and formatting. Text just hold the text contents.
If the above removes too much of the formatting you may have to parse the Contents string and remove any of the unwanted formatting strings (in this case it is probably just the "\Fbold.shx;" at the start of the Contents string).
Edit: Removed extra slash.
”Boost
