.NET
mendesva
Message 1 of 3 (240 Views)
cao.dbconnect, read labels from xref
240 Views, 2 Replies
02-02-2012 04:09 AM
Hi everybody...
I'm trying to read and update labels from Xrefs.
The meaning of it is to Reload all Labels in the Xrefs before I plot any Layout.
Autocad is working in SingleDrawing mode.
What do I have to do to bring xDB and dbConn together so I can "read/reload" the Labels?
Here is a snippet of my code (which doesn't work as expected) :smileysad:
Thank you for any kind of help.
(System: Win 7 64bit, Autocad 2012 64bit, VB express 2010)
Dim xDB As New Database(False, False)
xDB.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, False, "")
Dim acApp As Autodesk.AutoCAD.Interop.AcadApplication = DirectCast(Application.AcadApplication, Autodesk.AutoCAD.Interop.AcadApplication)
Dim acDoc As Autodesk.AutoCAD.Interop.AcadDocument = Application.DocumentManager.GetDocument(xDB).AcadDocument
Dim dbConn As CAO.DbConnect = acApp.GetInterfaceObject("CAO.DBConnect.16")
Dim lbls As CAO.LabelTemplates = dbConn.GetLabelTemplates()
Dim lnks As CAO.LinkTemplates = dbConn.GetLinkTemplates()
ADN Support Specialist
augusto.goncalves
Message 2 of 3 (236 Views)
Re: cao.dbconnect, read labels from xref
02-02-2012 05:12 AM in reply to: mendesva
What is the problem you are facing? Usually when creating Database to ReadDwgFile we use
Dim xDB As New Database(False, True)
Can you try that?
Augusto Goncalves
Autodesk Developer Network
mendesva
Message 3 of 3 (230 Views)
02-02-2012 05:42 AM in reply to: augusto.goncalves
Thank you for your reply Augusto,
I tried both: Database(False, False) and Database(False, True)
I don't know where exactly the problem is. All I know is that this two lines of code don't bring any result.
lbls ans lkns are empty!
So I guess dbConn.GetLabelTemplates() doesn't read from acDoc.
What do I have to do/change so lbls and lnks represent the labels and links in my Xref?
You are not logged in.
Ask the Community
