bpoly API
bpoly API
bpoly API
Hi there,
Is there an api wich works like the bpoly command in AutoCAD.
Click a point and the function gives met the points of the enclosed object.
I hope my question is clear if you got any questions pleaze ask.
Kind Regards,
Irvin
_gile
If you're targetting the 2011 SDK, look at the Editor.TraceBoundary() method.
Here's a quick and dirty
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace TraceBoundarySample
    public class TestCommand
        [CommandMethod("Test")]
        public void Test()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptPointResult ppr = ed.GetPoint("\nSelect inner point: ");
            if (ppr.Status != PromptStatus.OK)
                return;
            DBObjectCollection objs = ed.TraceBoundary(ppr.Value, true);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr =
                    (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                foreach (DBObject obj in objs)
                    Entity ent = (Entity)obj;
                    btr.AppendEntity(ent);
                    tr.AddNewlyCreatedDBObject(ent, true);
                    ent.Color = Color.FromColorIndex(ColorMethod.ByAci, 1);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Thanks verry much for your reply. Kind regards,
Irvin
