.NET
Active Contributor
gulzar25
Message 1 of 7 (183 Views)
block on curve
183 Views, 6 Replies
07-17-2013 10:41 PM
I am trying to move a block on a curve with reference to 2 points on the curve.I am facing problem when one point is on horizontal part of curve and other point is at an angle.How do i place the block at angle.Please help.
Thanks in advance
Valued Mentor
gasty1001
Message 2 of 7 (152 Views)
Re: block on curve
07-18-2013 02:19 PM in reply to: gulzar25
You can obtain the angle from the first derivative of the curve at that point, and calculate the rotation angle from that angle.
Gaston Nunez
Active Contributor
gulzar25
Message 3 of 7 (147 Views)
Re: block on curve
07-18-2013 07:37 PM in reply to: gasty1001
Thanks for the reply. Can you please help me with sample code.
Gulzar
Valued Mentor
gasty1001
Message 4 of 7 (138 Views)
Re: block on curve
07-19-2013 06:04 AM in reply to: gulzar25
The first derivative of a curve is the slope or tangent in a point of a curve, the function/method GetFirstDerivative returns a vector3D with Dx,Dy,Dz components , if your curve is planar, there is no need for Dz, so the tangent=Dy/Dx then theta=math.atan2(Dy,Dx), another method is to calculate the angle from X axis to the derivative vector. GetFirstDerivative should be a method for every object that inherits from the curve class. Try the docs on this topic.
Gaston Nunez
Active Contributor
gulzar25
Message 5 of 7 (94 Views)
Re: block on curve
08-01-2013 03:49 AM in reply to: gasty1001
I tried using the GetFirstDerivative method but i couldnt get direction.Can you please help me with sample code.
*Expert Elite*
norman.yuan
Message 6 of 7 (83 Views)
Re: block on curve
08-01-2013 06:28 AM in reply to: gulzar25
When you said "move block along...", did you mean you want user to drag a selected block/entity and when the mouse cursor is dragged, the block/entity moves along a given curve?
If so, one of my articles may be of help:
http://drive-cad-with-code.blogspot.ca/2012/03/moving-entity-along-curve.html
Active Contributor
gulzar25
Message 7 of 7 (70 Views)
Re: block on curve
08-01-2013 10:00 PM in reply to: norman.yuan
Hi Norman,
Thanks for the reply.Yes im moving block along a curve but im moving it with respect to 2 points.Im finding it difficult to get the direction.How do i get in which direction should i move.Any ideas??
You are not logged in.
Announcements
Need installation help?
Ask the Community
