block image.
block image.
Message 1 of 11
block image.
can anybody suggest how to use the block image so that
i can display it on my user form
all i know is that the autocad image should be converted to
system.image . can anybody suggest how i could go about with this.
thanks
namrata
Replies (10)
Message 2 of 11
What do you mean by block image?
Do you mean Block thumbnail Icon,
or something else?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5002238@discussion.autodesk.com...
thanks
namrata
Message 3 of 11
yes i want to create a thumbnail image of the block on my user interface
Message 4 of 11
See the sample code here:
http://www.caddzone.com/BlockIconSample.zip
wrote in message news:5005109@discussion.autodesk.com...
Message 5 of 11
Hello Tony
Thanks for the Sample.
Built in MSVC#2003 , Running in AC2006 :
For me, the class seems to recognise only blocks built and retained in the
document, not inserted blocks.
Regards
Kerry Brown
"Tony Tanzillo" wrote in message
news:5005286@discussion.autodesk.com...
Message 6 of 11
It's for displaying icons for blocks, not block insertions
(or perhaps I'm not undertstanding what you say below?).
If a block has no icon, you can generate one for it
using the BLOCKICON command.
"Kerry Brown" wrote in message news:5005334@discussion.autodesk.com...
Hello Tony
Regards
Kerry Brown
Message 7 of 11
Using the BLOCKICON command did the trick ... Thanks.
news:5005830@discussion.autodesk.com...
Hello Tony
Regards
Kerry Brown
Message 8 of 11
It's very old thread but...
I've tested Tony's example and works ok to me. The problem is that the produced bitmap is fixed size of 32X32 which is very low to use it in a form.
Any other workaround to get a better resolution?
How to avoid the use of BLOCKICON command and make the preview inside .net ?
Message 9 of 11
When I compile, I get the message, "The name 'BlockThumbnailHelper' does not
exist in the current context" Any suggestions? My operating environment is
Windows Vista, Visual Studio 2008 Professional, and AutoCAD 2009
Message 10 of 11
I was able to compile using AutoCAD 2008 managed libraries.
"J_Walters" wrote in message
news:6001611@discussion.autodesk.com...
Message 11 of 11
That code was for older releases where the PreviewIcon
property of the BlockTableRecord was not implemented yet.
In 2009 it is, so you don't need that workaround any longer.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"J_Walters" wrote in message news:6001971@discussion.autodesk.com...
