autoCad application setup
Hi
How can I create a setup for autocad  map application. I just want to load the tool (dot net Arx C#) application from user installation directory.
Murali
kerry_w_brown
Write the code.
Compile.
Either NETLOAD
or configure through the registry to demand load.
Regards
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Alexander.Rivilis
http://through-the-interface.typepad.com/through_the_interface/2010/09/building-an-installer-part-1....
http://through-the-interface.typepad.com/through_the_interface/2010/09/building-an-installer-part-2....
http://through-the-interface.typepad.com/through_the_interface/2010/09/building-an-installer-part-3....
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
kerry_w_brown
Alexander, I didn't think the AutoLoader would load from user defined folders ... I'll need to re-read those links.
Regards
Alexander.Rivilis
Regards
Kerry! I do not understand where these topics AutoLoader? These topic's are about creating setup (MSI). 😉
Expert Elite Member
kerry_w_brown
I may have misinterpreted the OP's question.
Regards
kerry_w_brown
Would be nice if the OP came back to comment 🙂
