• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    ads_queueexp
    488 Views, 8 Replies
    04-20-2012 03:02 AM
    Hi there,
    Does anyone know how to get “ads_queueexpr” to work under AutoCAD 2013?
    Private Declare Auto Function ads_queueexpr Lib "acad.exe" (ByVal strExpr As String) As Integer
    ads_queueexpr("(command""_dtext"" p1 8 0)")
    I asked ADN and they said it's now part of "accore.dll"
    But I'm still not sure how to reference it.
    Martin.
    http://www.designprosoftware.co.uk/
    Please use plain text.
    Re: ads_queueexp
    04-20-2012 03:24 AM in reply to: DesignProQuig
    change the read part (if you are speaking about AutoCAD 2013)
    Private Declare Auto Function ads_queueexpr Lib "accore.dll" (ByVal strExpr As String) As Integer
    - alfred -
    Alfred NESWADBA
    Active Contributor
    Re: ads_queueexp
    04-20-2012 03:31 AM in reply to: alfred.neswadba
    I feel a little silly for not spotting that ;-).  Thanks for the help.
    That has helpped, it now sort of works but now I receive this error:
    A call to PInvoke function <Mydll>::ads_queueexpr' has unbalanced the stack. This is likely because the managed PInvoke signature does not match the unmanaged target signature. Check that the calling convention and parameters of the PInvoke signature match the target unmanaged signature.
    ADN sent me this code in C#, I write only in VB.net & cou;dn't onvert using one of the on-line converters:
    using System.Text;
    [DllImport("accore.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "ads_queueexpr")]
    extern static int ads_queueexpr(byte[] command);
    UnicodeEncoding uEncode = new UnicodeEncoding();
    ads_queueexpr(uEncode.GetBytes("(Command \"StartOverrule\")"));
    Chers,
    Martin.
    Moderator
    Alexander.Rivilis
    Re: ads_queueexp
    04-20-2012 06:41 AM in reply to: DesignProQuig
    Imports System
    Imports System.Text
    Imports System.Runtime.InteropServices
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.Geometry
    Imports Autodesk.AutoCAD.EditorInput
    <Assembly: CommandClass(GetType(AutoCAD_VB_plug_in1.MyCommands))>
    Namespace AutoCAD_VB_plug_in1
        Public Class MyCommands
            <DllImport("accore.dll", CharSet:=CharSet.Ansi, CallingConvention:=CallingConvention.Cdecl, EntryPoint:="ads_queueexpr")>
            Public Shared Function ads_queueexpr(command As Byte()) As Integer
            End Function
            <CommandMethod("MyGroup", "MyCommand", "MyCommandLocal", CommandFlags.Modal)> _
            Public Sub MyCommand() ' This method can have any name
                Dim uEncode As UnicodeEncoding = New UnicodeEncoding
                Call ads_queueexpr(uEncode.GetBytes( _
                   "(command " + Chr(34) + "_ZOOM" + Chr(34) + " " + Chr(34) + "_Extents" + Chr(34) + ")"))
            End Sub
        End Class
    End Namespace
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Active Contributor
    Re: ads_queueexp
    04-20-2012 07:29 AM in reply to: Alexander.Rivilis
    Thank you very much for the help everyone, ;-).
    Martin.
    Moderator
    Alexander.Rivilis
    Re: ads_queueexp
    04-20-2012 07:38 AM in reply to: DesignProQuig
    Martin.
    Kudos and Accepted Solutions will be helpful. ;-)
    Active Contributor
    Re: ads_queueexp
    04-20-2012 07:48 AM in reply to: Alexander.Rivilis
    LOL, Done! :smileyvery-happy:
    ADN Support Specialist
    Re: ads_queueexp
    04-20-2012 04:49 PM in reply to: DesignProQuig
    Hi Martin,
    An alternative to ads_queueexpr for running a command at startup - http://adndevblog.typepad.com/autocad/2012/04/autoloader-the-startupcommand-parameter.html.
    BTW If you asked this question through ADN support, whoever answered you should have made sure you understood the specific changes required to your code. If you send me a private message with the Case number, I'll check the casenotes and 'educate' :smileywink: whoever answered you.
    Cheers,
    Stephen Preston
    Autodesk Developer Network
    Active Contributor
    Re: ads_queueexp
    04-21-2012 03:28 AM in reply to: StephenPreston
    Hi Stephen,
    I did get an answer and it was perfect.  I was flapping because it was getting close to 5pm, and I didn't know if I would get my answer for the weekend.  So no need to put the smack down. ;-).
    Martin.
