• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    acedcommand function in .Net managed classes
    1133 Views, 9 Replies
    05-21-2005 04:13 AM
    What is the corresponding functions or classes for thesethe arx Global
    function acedcommand in the .NET managed classes?
    Please use plain text.
    *Albert Szilvasy
    Re: acedcommand function in .Net managed classes
    05-22-2005 02:23 PM in reply to: tangferry
    There's none. This function isn't exposed via the .NET API. The function
    that comes closest is Document.SendStringToExecute.
    Albert
    wrote in message news:4852689@discussion.autodesk.com...
    *Tony Tanzillo
    05-23-2005 01:48 AM in reply to: tangferry
    They didn't expose it.
    Give the following a go, and see what happens.
    Note that the same exact rules that govern the use
    of acedCommand() in native ObjectARX apply here
    (namely, you can't use it from the Application context).
    ////////////////// CommandSample.cs ///////////////////
    // Copyright (c)2005 Tony Tanzillo, all rights reserved
    // Shows how to execute commands without resorting
    // to the kludgy SendStringToExecute method.
    // The command 'COMMANDTEST' draws a circle
    // centered at 2,2,0 with a radius of 4.0 units.
    using System;
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.Geometry;
    using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
    public class CommandSample
    const Int32 RTREAL = 5001;
    const Int32 RTSTR = 5005;
    const Int32 RT3DPOINT = 5009;
    [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl,
    EntryPoint="acedCmd")]
    extern static int acedCmd(IntPtr pResbuf);
    unsafe static int Command(ResultBuffer args)
    if( ! AcadApp.DocumentManager.IsApplicationContext )
    return acedCmd((IntPtr) args.UnmanagedObject.ToPointer());
    else
    return 0;
    [Autodesk.AutoCAD.Runtime.CommandMethod("COMMANDTEST")]
    public static void CommandTest()
    ResultBuffer args = new ResultBuffer();
    args.Add(new TypedValue(RTSTR, "._circle"));
    args.Add(new TypedValue(RT3DPOINT, new Point3d(2.0, 2.0, 0.0)));
    args.Add(new TypedValue(RTREAL, 4.0));
    Command(args);
    http://www.caddzone.com
    AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
    http://www.acadxtabs.com
    Active Contributor
    05-23-2005 06:29 AM in reply to: tangferry
    can you tell me how to use Document.SendStringToExecute functioon?An example is not bad.
    *Edward Merkins
    05-27-2005 08:37 AM in reply to: tangferry
    I am trying to learn C# based on examples that I find in this discussion
    group. With that said, based on the example below, I am receiving the error
    message: The name 'acedCmd' does not exist in the class or namespace
    'AcadTest01.CommandSample' Can someone help?
    "Tony Tanzillo" wrote in message
    news:4853121@discussion.autodesk.com...
    using System;
    else
    return 0;
    Command(args);
    Distinguished Contributor
    05-27-2005 08:54 AM in reply to: tangferry
    Something like this:
    Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_Zoom _E ", False, True, False)
    *J. Daniel Smith
    05-27-2005 09:22 AM in reply to: tangferry
    You'll probably have more success "trying to learn C#" at places like
    http://msdn.microsoft.com/vcsharp/gettingstarted/default.aspx; this
    discussion group more-or-less assumes knowledge of a .NET language.
    Dan
    "Edward Merkins" wrote in message
    news:4858845@discussion.autodesk.com...
    using System;
    else
    return 0;
    Command(args);
    *Edward Merkins
    05-27-2005 09:37 AM in reply to: tangferry
    Never mind - I had a typo.
    using System;
    else
    return 0;
    Command(args);
    *Edward Merkins
    05-27-2005 09:42 AM in reply to: tangferry
    So I take it you didn't no the answer. Don't post responses if you don't
    have anything intelligent to say! I am already somewhat familiar with C#.
    Just like the majority of people in this discussion group, I am trying to
    get a better understanding of using C# with AutoCAD.
    "J. Daniel Smith" wrote in message
    news:4858917@discussion.autodesk.com...
    Dan
    using System;
    else
    return 0;
    Command(args);
    *Russ Green
    01-05-2006 05:48 AM in reply to: tangferry
    Can Document.SendStringToExecute() be used (and executed) from within an
    application? I'm trying to write a VB.NET batch script processor and what
    seems to be happening is that the script doesn'tr execute until my app has
    finished. When I've tested my DLL code on a single DWG file my app runs all
    the way through, first setting FILEDIA to 0 then back to 1 but the command
    my app sends as a string doesn't execute until my app has finished, so
    FILEDIA is set back to 1 and the user has to browse for the script file to
    run.
    Is there a reson why SendCommand hasn't been exposed in the .NET API?
    I've successfully built a version of my app as an exe using COM but I'm
    trying to get my head into the .NET API. The code I have so far follows:
    THIS WORKS IN MY EXE
    Imports Autodesk.AutoCAD.Interop
    Imports Autodesk.AutoCAD.Interop.Common
    Public WithEvents AcadApp As Autodesk.AutoCAD.Interop.AcadApplication
    Dim AcadDoc As Autodesk.AutoCAD.Interop.AcadDocument
    Sub ProcessDwg(ByVal ThisDwg As String)
    'open the file
    AcadDoc.Application.Documents.Open(ThisDwg)
    AcadDoc = AcadApp.ActiveDocument
    'AcadApp.ZoomExtents()
    'process the script
    AcadDoc.SetVariable("filedia", 0)
    AcadDoc.SendCommand("script" & vbCr & """" & Me.txtScriptFile.Text &
    """" & vbCr)
    AcadDoc.SetVariable("filedia", 1)
    'close the file
    AcadDoc.Close(Me.chkSaveDWG.Checked, ThisDwg)
    End Sub
    THIS DOESN'T WORK IN MY DLL
    Imports acadApp = Autodesk.AutoCAD.ApplicationServices.Application
    Imports acadDoc = Autodesk.AutoCAD.ApplicationServices.Document
    Dim file As acadDoc
    acadApp.DocumentManager.Open(ThisDwg)
    file = acadApp.DocumentManager.MdiActiveDocument
    'process the script
    acadApp.SetSystemVariable("filedia", 0)
    file.SendStringToExecute("script" & vbCr & """" & Me.txtScript.Text
    & """" & vbCr, False, False, False)
    acadApp.SetSystemVariable("filedia", 1)
    'close the file
    file.CloseAndSave(ThisDwg)
    End Sub
