acdbmgd not found!!!
I keep getting this error from .NET whenever my main function goes into the sub function that uses the AutoCAD dll's...
An unhandled exception of type 'System.IO.FileNotFoundException' occurred in Lab1.exe
Additional information: File or assembly name acdbmgd, or one of its dependencies, was not found.
Can anyone let me in on the problem???? Thanks...
Ray
Hey Ray,
I believe you have to have AuotCAD's installation directory/folder in your
systems 'Path' variable. I thought
I had read that somewhere. I had that same problem, and that seemed to have
corrected it.
Larry
wrote in message news:[email protected]...
Lab1.exe
Ray
Larry can you explain this more? Wouldn't it make more since if autodesk published the assemblies in the C:\windows\assembly folder for public access?
