IN order to load/run .NET Framework 4.0 apps..i was told to modify my acad.exe.config file by removing the <!-- and --> from it....as shown below...
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version="v4.0"/>
</startup>
<!--All assemblies in AutoCAD are fully trusted so there's no point generating publisher evidence-->
<runtime>
<generatePublisherEvidence enabled="false"/>
</runtime>
</configuration>
Now, another user has installed AutoCAD 2011.....and I need to see if he can run a .NET Framewok 4.0 DLL from his machine...So I adjusted his acad.exe.config as shown above (just like mine).
After doing this....when he launches AutoCAD 2011, he gets an error....Cant' RUn AutoCAD - Re-Install...or you dont have right to tun it...blah blah blah.
Put the <!-- and --> back in his acad.exe.config file...and AutoCAD launches fine.
What's going on here? Why can't he make the change to the acad.exe.config file......but I can????
No...I guess that answers my question
