.NET
a bug in IsEqualTo method
1 REPLY 1
netcai
247 Views, 1 Reply
i want judge two points is same ,so I use the following code ,but result is always that two points is same. Even polyline(pol) just has two different points.
Point3d startPnt = pol.GetPoint3dAt(0);
Point3d endPnt = pol.GetPoint3dAt(pol.NumberOfVertices-1);
Tolerance tr = new Tolerance(0,0);
if (startPnt.IsEqualTo(endPnt))
1 REPLY 1
in reply to: netcai
I can confirm that this is a bug. Use the == or != operators instead. The
following works as expected:
Point3d pt1 = new Point3d(1, 0, 0);
Point3d pt2 = new Point3d(2, 0, 0);
Point3d pt3 = new Point3d(1,0,0);
Debug.Assert(pt1 != pt2 );
Debug.Assert(pt1 == pt3 );
wrote in message news:4881410@discussion.autodesk.com...
points.
Point3d endPnt =
”Boost
